Question about Peg Perego John Deere Gator HPX Ride on Toy
Where do you connect the charger for the battery
    Genius:
  • Peg Perego Master
  • 1,508 Answers
The battery is behind the front grille, you have to remove the screw in the middle and then pull out on the green plastic clips on each side then fold down
Posted on Jun 14, 2012
Mobility scooter battery serial connection charger question
if the charger is a 12-14 v charger you would have to charge 1 of the batteries at the time. connecting both in parallel during charging would cause a short. and in series (the way you have them wired) would provide too low a voltage for the batteries (6-7v each)
if the charger is 24-28v charger you would connect to the wires going from the batteries to the controls/motors (not the connection between the batteries) this will provide each of the batteries 12-14v charge
Mar 05, 2014 | Health & Beauty
Tip
How to Wire On-Board Marine Battery Chargers
Battery chargers are wired into a boat's electrical system. Wiring the charger to a battery switch permits the charging of the individual batteries or battery banks. The switch can be configured to charge both batteries or battery banks at once. Mounting the charger in the vessel keeps the charger where it will do the most good--connected to the batteries. This is useful if you are stuck with low batteries and need a recharge. Power from a generator, shore power or even AC power from another vessel can be used to get you going again
Instructions Things You'll Need:
Battery charger
Battery switch
Battery cable (sized)
Cable cutters
Razor knife
Battery terminal lugs
Lug crimper
Terminal kit
Terminal crimper
Hammer
Step 1
Mount the battery switch with the mounting kit provided by the manufacturer. The switch should be accessible but close to the battery or battery banks.
Step 2
Mount the battery charger in a location that will be accessible but protected from the elements. Mount the charger close to the battery switch to reduce the size of the charger leads.
Step 3
Connect the battery cables to the battery switch. Mount the battery cables onto their corresponding terminal studs on the battery switch.
Step 4
Lay out the battery positive cable from the charger to the switch and cut it to length with the cable cutters. Strip 3/4 inch of insulation from the cable ends with a razor knife. Splice the cable to the hot wire from the charger with a **** connector and the terminal crimper. Crimp a terminal lug onto the battery end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery switch positive output terminal.
Step 5
Lay out a battery cable from the charger to the battery negative terminal block. Cut the cable to length and strip 3/4 inch of insulation from the ends with a razor knife. Connect the battery negative cable to the charger negative power lead with a ****-splice and the terminal crimpers. Crimp a terminal lug onto the terminal block end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery negative terminal block post.
Tips & Warnings
Set the switch to "1," "2" or "both" to charge battery bank 1, bank 2 or both batteries at once.
on Jan 07, 2010 | Mercedes-Benz C230 Cars & Trucks
Charging the battery
If you have a battery charger, remove the battery cover to expose the battery terminals then you can connect the battery charge to the battery.
Make sure you connect the positive lead from the charger to the positive terminal on the battery and the negative lead from the charger to the negative terminal on the battery before you power up the battery charger.
When you have finished charging the battery, power off the battery charger before you disconnect the leads from the battery.
Jul 03, 2012 | 2009 Hyosung GT 250
How do i connect a battery charger to charge battery on ford fiesta style
The positve cable of the charger (red lead) goes to the post of the battery marked (+), the black lead of the charger goes to the battery post marked (-) a black cable at the battery.
Feb 08, 2012 | Ford Cars & Trucks
Recharge battery Cadillac Deville 2005
You do not need to remove the battery to charge the battery. When you connect the charger you MUST be careful to connect the charger's positive lead to the positive terminal to the battery and the negative lead to the negative lead to the battery before you turn on the battery charger. Connecting the charger leads the wrong way around most likely damage the vehicle's electronics.
When you finish charging the battery turn off the charger before you disconnect the charger leads. This will prevent arcing between the leads and the battery.
Jan 14, 2012 | 2005 Cadillac Deville
Weak battery, I would like to connect a battery charger to it. How do I do this with out taking the seat off? Or is that possible?
There is another way but it may not be any easier. You can connect the positive clamp of your battery charger to the connection where the large battery cable coming from the battery connects to the starter. Connect the negative clamp to a good frame ground.
The best method of maintaining your battery is to use one of the "smart chargers" on your battery. A "Battery Tender" or "Yuasa" smart charger comes with a pigtail that you connect to your battery. Tuck the pigtail in somewhere that it can't be seen when you ride and when you get back home, plug the charger to the pigtail. Your battery will stay fully charge without be boiled dry like the big chargers will do . It will increase the life of your battery as well.
Good Luck
Steve
Jan 05, 2011 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Procedure for attaching a battery charger to a 2004 XL1200 Sportster Roadster please?
If you remove the seat and the battery cover, you can connect the battery charger positive lead directly to the positive battery terminal. Or, you can connect it to the battery connection at the starter, whichever is easiest to get to. Connect the negatve charger clamp to either the negative battery post or any good ground on the engine or frame of the bike. Once connected, turn the charger on with a 2-amp per hour charge rate.
Good Luck
Steve
Dec 19, 2010 | Harley Davidson XL 1200 R Sporster...
How do you change a battery in a 1999 chevy venture van
Assuming you have a battery charger. Do not plug charger in until after it is connected.
1. Open hood & locate battery.
2. Identify the positive terminal of the battery (usyally has a red cover or red marking.
The battery has side terminals (not posts like nonGM batteries)
4. Connect the + red clamp the the positive terminal wiggle it a little to get good connection.
5. Connect the negative black clamp to the engine block, a handy bracket on engine or the negative terminal on the battery. DO NOT CONNECT TO ALTERNATOR
6. Be sure connections are secure.
7. Plug in charger it should show charging. Leave it over night
8. Before disconnecting charger disconnect power to the charger.
THE FUMES OF A BATTERY ARE EXPLOSIVE DO NOT USE FLAMES NEAR BATTERY
DO NOT ALLOW SPARKS NEAR BATTERY!
Dec 08, 2010 | 1999 Chevrolet Venture
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
Aug 10, 2010 | Harley Davidson FXR Super Glide...
New batteries does not seem to fully charge. tested the output of the charger with meter and it shows no voltage on the output of the charger, but the two lights flash quickly when plugged in to the wall...
The measurements below are for a 12 volt charger or across one battery at a time. In a 24 volt charger or across both batteries at once, double the values.
The charger will not show any output unless connected to a battery. To test the charger, attach the charger to the battery but do not plug in the charger. Connect a meter to the battery and read the voltage (9.8v - 11.6v).
Now plug in the charger. Read the battery again (13.6 - 14.2v).
The voltage must not be higher than 14.8 on the battery or the battery will over-charge - the charger needs service. If the voltage does not come up to 13.2v, the charger is not running. Again, the charger needs service.
Be patient. You can wait ten minutes and measure again. Batteries respond slowly to the charger.
Apr 02, 2010 | Pride Jazzy 1113 Power Chair
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
