Question about ASUS DRW 0402P DVD-RW Burner
Cd burning Every time I try to burn a home video from my camera the CD+R does not show up on the list. It doesn't even try to burn the video. Do i have the wrong type of CD?
  • 871 Answers
Try to use nero so that you can get the complete information regarding what type of cd your burner supports. we really cant say as of now not until you have posted it here. Possibly the cd is not supported.
Posted on Mar 24, 2008
SOURCE:
My laptop is not burning my videos properly to a dvd?
You can download a free video burner like FreeMake sounds like media player is over compressing the video when its ripping.
Sep 20, 2012 | ASUS U56E-BBL6 15.6in Laptop i5 2.4GHz 6GB...
Trying to burn a movie from a new burner by samsung 22x 768564 dvd, but the green line doesn't keep up with the timer, i let 1 movie burn for 12 hours on timer and all it did was encode, didn't...
should not take 12 hrs to burn
does it burn data cd/dvd or audio cd/dvd's ?
you might have to burn it as an ISO image
this might be because you have not selected the option to burn a dvd movie you might have selected another option ie:burn data audio or your burning software does not support movie dvd burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Sep 25, 2011 | Samsung Computers & Internet
I bought some old radio shows on from amazon, and it such a large number of shows that they put them on a dvd . I would like to down- load them on cd so I can play them in my car or cd players....
It depends on the format that they were put on the DVD initially, to play these on a car stereo or CD player they may need converting to be recognised by a standard CD player.
In vista, you can use Windows Media Player to do this. I'd recommend copying them to your computer from the DVD by creating a folder called "radio shows" or similar in an area you can easily find again On the desktop is a good place.
Now open Windows Media Player and insert a blank CD into your CD/DVD drive (I'm assuming you have an optical drive that will burn cd's)
In the menu of Media player, you will see a tab called "burn", click on it and you get the option on the right of the pane to "create a burn list". Make sure the icon says audio cd
Now open the folder you just created called "radio shows", select the first shows you want to burn to cd and drag the file onto the area marked "drag items here to create a burn list"
As you add files the CD meter should start to fill up, when it is near full, you can click on "start burn" which is at the bottom of the pane. Your compilation should now burn to a cd, repeat for the next cd.
If you get stuck, under the burn tab, there is a help with burning guide
Jul 24, 2011 | Computers & Internet
My music after i burn it it will not play on my cd player
Hi Martin!
  • If your CD supports MP3, try burning another CD using slower writing speed.
  • If your CD doesn't support MP3, make sure to burn a regular Audio CD, instead of MP3 disc.
If you are satisfied, rate my solution with 4 "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Apr 25, 2011 | Audio Players & Recorders
I am trying to burn a cd on my Acer Aspire 5536-5255 using WMP and it isn't working?
In Windows Media Player, click Library and then, in the List pane, click <List Name> List, and then click Burn List, as shown in the following screen shot.
  1. If you need to clear the list before beginning, click Burn List, and then click Clear List.
  2. Drag a folder from the Contents pane or songs from the Details pane to the List pane to create a list of songs to burn.
  3. In the burn list, drag songs up or down to arrange them in the order you want them to appear on the CD.
  4. Insert a blank CD-R or CD-RW disc in the CD drive.
  5. In the List pane, verify that the songs you have selected to burn will all fit on the disc. If necessary, remove songs from the list by right-clicking a song and then clicking Remove from List, as shown in the following screen shot.
It is possible that a song will not fit even if the total time exactly matches the CD length, because the Player inserts two seconds between songs when burning. Click the Start Burn arrow and verify that Audio CD is selected, as shown in the following screen shot.
lick Start Burn.As the CD is burned, you can check its progress in the burn list. Burning a CD will take some time.Notes It is recommended that you do not try to perform any other actions while burning a CD. For example, playback may be affected if you try to play a music CD while burning a CD.
You cannot burn additional files to a CD after burning is completed. If you are using a CD-RW, you can erase the entire CD before using the Player to burn files to the CD again.
Nov 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
Cd burner makes blank cds
try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Jul 07, 2009 | Dell Dimension 4600 PC Desktop
Cannot burn a video to CD using Sony Picture Package
check your cd burner device if correctly connected to your pc. see and first boot if recognizable like seeing your ide's and first boot. see if your cd burner device is connected. use NERO as your burning software hope that helps!
CHARCOIS
Sep 13, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Downloading Video
In order to burn a DVD you need to use the 1394 interface. If you use the USB interface then you have the option to only burn VCD. However, i could not even burn the VCD using the USB interface. It refuses to recognize that there is a new CD-R in the PC.
Can anyone help please?
Feb 24, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Teac DW-224E-c - cannot burn DVD's
The answer is what you profess. The drive can burn CD's, read CD's and also read DVD's. Everytime I try and burn a DVD I have an unrecognized drive and the properties always show no disk: The drive burns CD's ie;music, but cannot burn DVD it can only read DVD like you say!
Sep 10, 2007 | Teac DW 28E CD-RW/DVD-ROM Burner
Cannot burn CD from Kodak Easyshare Software
If you are using the Pro version of XP, it will burn your photos to the CD itself. As I recall, this didn't work in the Home version of XP, but you could try it. Simply drag and drop the photos onto the burner drive from within Windows Explorer. Once they are all there, I think there's a menu item which tells XP to perform the burn and eject the disk. All that assumes that the burner is working OK on your machine
Aug 30, 2005 | Kodak EasyShare LS443 Digital Camera
Open Questions:
AOL MAil+ SuPPoRt NuMbER {1^/855~/536~/5666-}+++ KENTUCKY This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 18, 2019 | AOL Computers & Internet
See all ASUS DRW 0402P DVD-RW Burner Questions
ASUS DRW 0402P DVD-RW Burner Logo
29 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
