Question about Radio Shack Cinego D-1000 Multimedia Projector
Cover on projector.
The top cover will not stay close. Where can I get the cover replaced? I have had the projector for about four years.
  • mcteacher Mar 22, 2008
    I need to replace the cover on my D-1000. It want stay closed. Where I can send it to get repaired.
  • 563 Answers
Hi there
Try searching for your nearest dealer of this specific brand on the net.
Posted on Apr 03, 2008
Hello! I have a DELL 1209S that the picture is wavering. Is it spring?! Some vertical lines almost invisible in the background are also perceived. What can it be?
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Dell 1209S DLP Projector
Red warning light
  • 2
  • 3
  • 4
  • 5
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
The lamp cover light is blinking then projectoe gose off
hi,
There is two possibilty for this problem one is the lamp cover is not properly placed and the second one is the lamp has reached end of its usful life span.
First of all check the lap cover is propely placed or not. if its ok then try to reset the lamp hour.
For that press the menu button and select setup and then select Lamp setting and reset the lamp. It is reccomented that the lamp reset should only be don after replacing the lamp.
OK
Oct 06, 2011 | Sony Bravia® VPL-AW10 Projector
I have a sony vpl-cs5 but is not turn in on, some body can help me, have a blinking led that say lap/cover.???
That could indicate the following-
1. The lamp cover or filter cover aren't properly closed. Try shutting the projector down> opening both covers> closing them> restart
2. The lamp is nearing the end of its life or is faulty and you'll need to replace it.
May 04, 2011 | Sony VPL CS5 Multimedia Projector
The power light is red, and the lamp light is blinking red. can you help me. thankyou
This indicates that the lamp cover is not properly closed. Disconnect the mains power and carefully open the lamp cover, reseat the lamp and close the lamp cover taking care not to force it.
A fault of this type would be common after a lamp has been replaced, or at least removed for inspection.
Feb 21, 2011 | Hitachi CP-X200 LCD Projector
How do I replace the cooling fan in benq pe8700
There's more then one fan inside the projector. I think I counted 3 when I opened mine up. Two are easy to get to, the other is underneath. on theleft side looking from the front. You have to take off the back surround cover in onder to remove the top cover. The top cover slides back and lifts up. Be careful because there's a wire harness running to the top cover control panel. Disconnect it then you have access to the fans. Wish mine was that easy to repair.
Feb 24, 2010 | BenQ PE8700 Multimedia Projector
Shutting off
You have a classic temp. sensor issue, common with all sanyo projectors. Very easy to repair. Take the top cover off, check the little black pot like thing mounted nexto/on the lamp housing, It has a small white head... Thats the temp sensor. When the unit gets hot, the sensor opens the power circut, so that no power can come through. All you have to do is push the little white head back down, so that it closes the circut, and subsequintly restores power.
Here is the service manual free, It will give you alot more detail.
http://yama.co.za/forum/index.php?topic=146.0
Sep 09, 2009 | Sanyo PLC XU35 Multimedia Projector
Lamp cover light flashes even with new lamp
Look closely by the cover there is a small sensor there, could be a pice of dirt and door not completely closing get a cleanpaint brush or little brush and clean area..Good Luck
Jun 25, 2008 | Sony VPL CS5 Multimedia Projector
Projector turns off after 30 seconds.
I had the same problem I replaced the motor/lense cover unit at the cost of $AU140.00 and that fixed it.
Leckie
Oct 09, 2006 | Sony VPL CX5 Multimedia Projector
19 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
