2006 Dodge Ram Logo
Posted on Apr 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY 2006 DOdge ram Thunder Road's windows dont work. They used to work i bought the truck new. All of a sudden all the windows from every control dont roll down their own windows as well as the driver side control doesnt roll down any window??? All the fuses are okay. I had the wires in the door checked and they have power. What else could i look into?
Anonymous
Level 2:
  • Expert 373 Answers
  • Posted on Apr 23, 2010
Anonymous
Expert
Level 2:
Answers
373
Questions
0
Helped
199331
Points
633
Your truck also has power relays working with the fuses. each door has its on circuit except the main controller in drivers side door. if u cannot control anything from drivers side then look at the relays for possible cause to your problem.
  • IKevin Sacra Jan 25, 2011
    I am having the exact same problem and it is driving me crazy. What did you end up having to do to fix the issue? Any issue woujld be extreamly helpful.
  • Anonymous Oct 31, 2011
    Can you tell me where I find the circuit brakers
2006 Dodge Ram 1500 5.7 4x4. What fuse runs the 4x4 please?
It isn't specified. There is more than one fuse that covers transmission. You would need an auto electrician or a transmission expert to connect a pro grade scan tool computer and diagnose if the switch or solenoid is faulty. A scan tool at this level is bi-directional and can command solenoids to operate and confirm that they do.
https://www.google.com/search?q=auto+electrician+near+me
Fuse Box Diagram Dodge Ram 1500/2500 (2002-2009)
https://fuse-box.info > dodge > dodge-ram-1500-2500-...
Fuse box diagram (location and assignment of electrical fuses) for Dodge Ram / Ram Pickup 1500/2500 (2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009).
2006-2009 Dodge Ram 1500/2500/3500 Fuse Box Diagram
https://knigaproavto.ru > ... > Dodge > Ram (Pickup)
Nov 16, 2018 - 2006-2009 Dodge Ram 1500/2500/3500 Fuse Box Diagram ; 5, 20, except Base: Sunroof ; 6, 40, Diesel ('06): Wastegate Solenoid, Drive Fan Radiator ; 6 ...
2006 5.7 ram 1500 fuse box diagram - DodgeForum.com
https://dodgeforum.com > ... > 3rd Gen Ram Tech
3rd Gen Ram Tech - 2006 5.7 ram 1500 fuse box diagram - I was hoping somebody had a fusebox diagram kicking around. The inside of my fuse box cover does not ...
Fuses and relay Dodge Ram 2002-2008
https://fusesdiagram.com > Dodge
Mar 27, 2017 - For Dodge Ram 1500, Dodge Ram 2500, Dodge Ram 3500 - 2002, 2003, 2004, 2005, 2006, 2007, 2008 model year. Cigarette lighter fuse - Fuse box in ..
1helpful
I have been 49 Dodge Ram pickup Barberton all the gauges in the lights and wipers going on and off on and off and everything else but her uncle Kate what would be the problem
2006 Dodge Ram Tachometer fix - YouTube
? 6:24
https://www.youtube.com/watch?v=ufQ1t4eOwkM
Aug 8, 2013 - Uploaded by Marc Reiter
I've been putting up with my inaccurate tach on my 2006 Ram for a couple years. ... 22:49. International dash gauge cluster fix this is a how to video dont ... 2006 Dodge Ram Truck Tachometer RPM gauge repair service ... Installation of a Trailer Brake Controller on a 2006 Dodge Ram Pickup - etrailer.com ...Missing: barberton ‎el
Dodge Ram Cruise Control Fix - YouTube
? 8:44
www.youtube.com/watch?v=ppcUyQZ14AE
Jan 5, 2011 - Uploaded by Axidias79
Here is how to fix the cruise on the vacuum actuated dodge ramcruise controls. I think they did that from 94-01 ...Missing: barberton ‎fluctuates
1998 dodge durango window fog
may be a blocked vent in the windscreen vents. could be at the windscreen end or at the controler in the heater. if you dont have a pollen filter fitted rubbish from the road i.e leaf's can get in and block it up.
1helpful
I have an 2006 Dodge ram 2500 2x4 Maual. My windows all of a sudden stopped working. I first noticed it when I went to roll down the windows by using the main switch on the drivers side door. Then i...
IF YOU ARE SURE THERE IS POWER COMING OUT OF THE FUSE OR CIRCUIT BREAKER, WITH IGNITION SWITCH ON, IT IS PROBABLY A BAD GROUND OR THE SWITCH HAS COME UNPLUGGED. THE GROUND WIRE IS BLACK & IS PROBABLY FASTENED SOMEWHERE ON THE LEFT KICK PANEL
1helpful
2answers
The back pasenger electric window of my 2006 dodge ram 3500 deisel wont go up.both the switch on the door and the switch on the driver control door dont work. checked the fuse box but found nothing labeled...
hi, there is a relay for the windows. in the fusebox (s) there should be a relay for each window. these relays do fail (open circuit on switch side). the feed POWER side may be shorted. these circuits are hard to find the fault, but check all the door relays. the motor can stick and put heavy current to blow the fuse, if you leave the engine OFF and put the ignition ON press the other window and listen for this relay noise. a click can be heard to pinpoint the location of other relays. once you find these switch relays to determin if these are working and use this to put the rear window back up. gerry
2007 dodge ram fuse problem
my 2008 dodge ram is displaying no fuse underneath the spedometer. it makes a clicking noise about 5 times and turns over fine. runs normal/drives normal. it delays when turning off (i turn the key off and it takes about 5 seconds to turn off) remote entry does not work.
Back up lights
Have it checked at dealer. I hope your warranty is still good. Probably the same problem wit electrical problems that spring up with other years. Mine needs a new Front Control Module and Power Distribution Mudule due to an internal short in both. How would this happen? Maybe the ******* that designed the idea to put the fuse box with two circuit boards under the hood and not have it sealed up to keep the moisture out. Corosion from moisture causes circuit boards to short out. I hate my Dodge. It costs too much to keep the piece of **** on the road.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
