Question about HP Compaq Business Notebook NX9010
Ram i know to replace the ram but do not know what ram i should buy
    President:
  • 1,950 Answers
You need to purchase DDR SDRAM - 266 MHz for your laptop (up to 1GB).
Posted on Mar 22, 2008
SOURCE:
Graphic card
RAM can be located under the keyboard, or more commonly on the back will be a small panel with a picture of ram on it. The graphics or GPU is soldered on to the motherboard in most laptops and isn't replaceable. You would either need to buy a new motherboard $150-400 in most computers and replace it or buy a new computer.
Jul 09, 2012 | Toshiba Satellite A60 Notebook
How do i increase ram in my evesham notebook model no8615
go to a store or online store such as best buy or radio shack and purchase laptop ram (1gb, 2gb, 4gb, etc.). on the bottom of your laptop remove the ram panel and switch the ram so you have more ram.
Jun 27, 2010 | Office Equipment & Supplies
I have a » HP Pavilion Dv4000 Notebook PC, Needs some Q&A
your graphics are integrated and replacing the graphics would be a nightmare.
As for your RAM, yes this is the correct product to purchase and it is easy for you to install.
the maximum amount of RAM your laptop can hold is 2Gb (2x1Gb).
Hope this helps
Jan 26, 2010 | HP Pavilion dv4000 Notebook
2004 Ram 1500 Hemi -- Tried to buy a fuel filter and Fram book said Non-Servicable. Besides the dealer, where can I get one off the shelf?
i dont think the rams have aservicable filter. the only 1 i know of is located on the fuel pump and typically does not require replacement and is only serviced in the pump assembly
Nov 19, 2009 | 2008 Dodge Ram Pickup 1500
My compaq presario V2000 has frozen after I loaded an antivirus
Freezing is usually a symptom of failing ram. Your motherboard could also be the culprit. It is tough to effectively diagnose because memory and systemboards work so closely together. Cheapest thing to try is replace the ram, and since you are buying ram, go ahead and buy a larger amount. Install 1gig instead of 512 meg. (make sure your pc can use the memory upgrade). Replacing the ram with new ram will let you know that the memory is new, and if the issue persists, you know it is not the ram. If the issue persists after replacing the ram, that means you should replace your system board.
Oct 01, 2009 | Compaq Presario 5716 PC Desktop
I want to upgrade my lenovo laptop ram memory from 1gb to 2gb by adding one more stick. i currently have ddr2 PC2-5300(333MHz) latency 5 5 5 15 2T RAM my friends advised me that BLUE SCREEN ERROR occurs...
The rule of thumb with RAM is to always buy matching pairs. So instead of buying one new stick of 1gb its a better idea to buy two of the same kind and replace the one that is currently in there.
Before you even think about doing this, head over to lenovo's website and make sure that the computer is compatible with 2gb(from the speed of the ram im assuming that it will, I don't know of many DDR2 computers that cant have 2gb.) you may also be able to get ram that is faster if it is compatible, The website will have all this info.
Jul 12, 2009 | Computers & Internet
Buying RAM to my ASRock(845GV R5.0) Motherboard ?
it can support up to 2GB ram maximum FSB 533/400MHz,
Memory Supported RAM Technology: SDRAM, DDR SDRAM
RAM ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600, PC100, PC133
Aug 10, 2008 | Asrock P4I45GV R5 Motherboard
Gateway E4100 Mid Tower RAM install
no need to install RAM in pairs.
you can buy and install memory but it should be the same model that you have now e.g. DDRII RAM Modules.
you can max out the RAM 4 gigs
Mar 30, 2008 | Gateway Sb-4100-A PC Desktop
Hp dv5000 problem
ill suggest o you like many technician do when they messed around their workstation...
if that what you have done is similar to a desktop replacement of ram probably you just knocked out some of the components inside...
first thing check the specs of your old ram and compare it to your new ram... its not just buying the higher capacity but also considering the type of ram you are buying... you can't just put oddly different rams to replace the old one just because its has higher capacity... go to the store where you bought the new ram and show them your old ram for an assistance, hopefully the guy selling the ram knows what type of ram you really need (they should ask you that on the first place).
if the two rams you bought are similar to each other then you save your time going back to the shop where you bought the new ram... just open your system and make sure everything sets firm and if you can just the ram out and get a brush.... brush the dirt out of the connectors and use an eraser to your ram and erase the contact points...
if this helps just rate me to give thanks ok...
Jan 20, 2008 | HP Pavilion dv5020us Notebook
HP Compaq Business Notebook NX9010 Logo
57 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
