Question about Whirlpool Dishwashers
Dishwasher Rinse cycle does not seem to work during normal wash cycle.
I have a 10 year old Whirlpool quietwash plus Dishwasher. Recently we had a power outage and since then the rinse cycle does not seem to function during normal wash. I have tried running different rinse cycles and wash cycles and I can't get the rinse cycle to work during the regular wash cycle.
This is the first time we have ever had a problem with this machine.
What do you recommend?
SOURCE:
SOURCE: Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
  • 8 Answers
SOURCE: bosch dishwasher SHU66C02UC - Rinse Agent issue
Does soap draw open at right time?
Same solenoid opens soap draw as injects rinse aid.
Turn up hardness counter ?
Any blockages in dispenser unit its-self?
OTHERWISE CALL IN THE PROFFESIONALS !
Posted on Apr 25, 2008
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
  • 338 Answers
SOURCE: Whirlpool Type 575-0 Dishwasher has a film on the glass ware
try only filling the detergent cup halfway. but before doing that run a cup of vinegar through the dishwasher. that should solve the problem. you are using to much detergent. plus use powder detergent if it is stated in your owners manuel.
Posted on Nov 26, 2008
aborcass
  • 2651 Answers
SOURCE: washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Posted on Feb 23, 2009
Timer light on front panel of dishwasher has stopped working--how is it replaced?
Most of the led lights are fused to the circuit board. Sounds like the circuit board is going or gone bad. I'm not sure because you did not give the model of the dishwasher.
Most of the control lights are led and do not go bad. But the circuit board that controls the lights can go bad. You may be able to fix the control circuit board but replacing it would be easier.
Oct 14, 2014 | Maytag Dishwashers
Why is my whirlpool dishwasher making a loud noise during drain, wash and rinse cycles?
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher is not cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
k
Apr 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2200 dishwasher, the detergent
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Aug 27, 2009 | Whirlpool GU2200XTSS Built-in Dishwasher
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
43 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
