Sansui TVS273 Do I need to purchase a converter box, or am I ready to receive a digital signal?
  • 1 more comment
  • navnitsm Apr 29, 2008
    I just bought a used Sansui TVS 273 TV , Is this set HD-Ready, how do i watch the HD channels on this TV?
  • burt1013 Dec 31, 2008
    do we need a convertor box or does this already set up for digital broadcast
  • Anonymous Mar 19, 2014
    How do I get the digital signal to receive local area channels.
This tv is not digital.
Posted on May 12, 2008
Need to know how to change and setup for use of antenna
Purchase your UHF/VHF antenna. The antenna can also be purchased at most electronic and retail stores. Consult your list from Step 1 and see how powerfulicon1.png the over-the-air signals are for your specific address. Purchase your antenna based on the broadcasting power you need to receive a clear picture on your TV. You might be able to get away with an indoor antenna if your signal strength is strong enough. If not, you'll need to purchase an outdoor antenna.
  • 4 Install your antenna (or have it done professionally) according to the building codes of your area. If you must use an outdoor antenna, it is a good ideaicon1.png to have the antenna professionally installed. This ensures that it is properly grounded on your roof, not too close to electrical wiring and stable during inclement weather.
  • 5 Hook the converter box up to your television using the cable that came with it (F Cable). Hook your antenna up to the converter Box. Turn on your TV and converter box. Tune your TV to channel 3 and press "Scan" on the digital convert box. Allow the box to scan for your available channels.
  • 6 View your picture and adjust your antenna accordingly for the clearest over-the-air feed. You should only need to make adjustments once. If you are having a difficult time getting a clear picture, use a signal strength indicator to see where you receive the most powerful signal.
  • Read more: How to Replace Cable TV or Dish TV With Antenna TV ' eHow.com http://www.ehow.com/how_5228282_replace-dish-tv-antenna-tv.html#ixzz2RrACTyTI
    Mar 29, 2013 | Sansui 19 in. LCD TV
    With Sony KP-46WT520 46 in. Rear Projection HDTV-Ready Television, does it receive digital signal over air? Do I need the separate digital converter box? What do I hook up where to get channels? and how do...
    Hi Gwen,
    This TV set doesn't have a digital tuner and you will need a digital converter box to receive over the air channels.
    You still an antenna to receive the signal and then to connect it to your digital converter box. The programming should be easy.
    The converter box should come with the user's guide on how to hook it up and program it.
    Jan 13, 2018 | Sony KP-46WT520 46" Rear Projection...
    All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
    All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
    http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
    Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
    I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
    Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
    Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
    Have a sansui tvs273 tv. Need to switch it from
    If your set does not have a menu button built into the set your out of luck unless you can find a replacement or universal remote.
    Sep 11, 2009 | Sansui TVS203
    Sansui tv dtv2784
    No this TV is not HD ready. However it is digital (ATSC) ready meaning now that most of the analog brodcasts have stopped it will receive the digital broadcasts so you don't need a converter box. Since it can only display 480i resolution it is not HD ready. You would need a TV that can display 720p or better to be considered HD ready.
    Jan 04, 2009 | Sansui 27" TV
    Convert my Sony kp61hs10 HD Ready to receive HDTV
    no need to convert ,,i have same tv,,hdready just means it has no built in converter. You just need a HD converter box or a cable box or dvr that is also an HD receiver.
    Dec 14, 2008 | Sony KP-61HS10 61" Rear Projection...
    Is the is TV Digital or Analog?
    if your grandmother has cable or satelite tv she already has a digital signal however if she justs gets her locals she will need a converter box. the goverment is giving free coupons for this or she can go to walmart and purchase a directv converter box for about $50 she will not have directv but the box will convert her signal.. the tv has nothing to do with the signal. she will not need a new tv.
    Dec 12, 2008 | GE 25GT516 TV
    Analog/Digital
    HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
    Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
    Televison & Video Logo
    282 people viewed this question
    Top Televison & Video Experts
