Question about Samsung LN-S2651D 26 in. LCD Television
Blank screen When i turn the tv on it has sound blacklight is good but screen will not change its black what could be wrong
  • 74 Answers
If you have menus (on screen display) then the tv may be ok and your signal source is ng or hooked up wrong. If no menus then the tv needs expencive parts inside
Posted on Mar 25, 2008
How do I fix a Samsung LED TV that has no sound and a black screen. I did verify it does have blacklights.
You have already changed every board in the TV, presume all of the board are functional, the problem would be ether the back light ASSY, or the panel itself.
Jun 30, 2017 | Samsung Televison & Video
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
Black Screen
Now turn on tv.Have picture flicker few sec.than dies,have sound only left?Yes,than the 1 or 2 long LCD inverter boards are dead.Tries websites liike shopjimmy.com,Ebay.com to buy these refurbishes 1 or 2 long LCD inverter boards for the replacement.
Jul 17, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
Samsung SyncMaster 243T blacklight
indeed, probably the backlight...
Nothing to do about that but repair or replace, sorry...
Nov 13, 2008 | Samsung SyncMaster 243T (Black, Silver)...
Samsung LN-S2651D 26 in. LCD Television Logo
192 people viewed this question
Henry  Thomas
Henry Thomas
