Samsung LNT3253H is making a high-pitched noise
My Samsung LNT3253H is making a high-pitched noise after it's been on for a while. The TV is only a month old. I have it in an entertainment center and am wondering if it is getting too hot, causing the high-pitched noise. Is that the possible cause? Any others? Thanks.
  • nlbdr Apr 18, 2008
    good picture but has developed a high pitch noise started out where you barely hear it but gradualy grew louder
  • Beth 8285 Jun 12, 2008
    Mine is making the same noise. I have a tech coming out next week to check it out. What should I expect? They know what the issue is with the noise?
I had the same issue. The tech that came out today removed the transformer on the power supply board, "resealed" it, and replaced it (re-soldered the same part back on) -- the transformer apparently vibrates because it was not properly sealed. BTW, mine was about the fifteenth that he has performed this repair on within the past couple of months -- all 32" and 26" Samsungs. Now, it appears to be absolutely silent.
Posted on May 20, 2008
  • 59 Answers
The high-pitched noise you are hearing is the color wheel. It is a very common problem in Samsungs.
Posted on Mar 23, 2008
Frigidaire refrigerator only 6 months old making high pitch noise constantly after door has been opened. What is causing this?
Hello friend, thank you for your post!
Based off the information you have provided your Frigidaire refrigerator is making high pitched noises after the door has been opened. With our current refrigerators the new modern, high-efficiency compressors operate much faster than older models. The compressor may have a high-pitched hum or pulsating sound. If you feel that further assistance is needed please contact your manufacturer for any warranty coverage. -Matt
Feb 02, 2016 | Frigidaire Refrigerators
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
High pitch noise when on or off
Some ferrite cores of power supply regulator might poise this problem. Check for it.
Jul 07, 2012 | Samsung P2370HD 23 in. TV
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Samsung SlimFit 30" high pitch whining noise
I have had the same high pitch tone problem for several months after about 20 minutes of use. It is so bad it's rendered the TV almost unwatchable. I contacted a repair place from Samsung's website. I was told that is likely the flyback transformer. I don't know what it is, but it sounds cool like a flux capacitator. I was told it would be about $100 to fix. However, I have had very little luck getting the repair shop to order the part and do the work.
Sep 04, 2008 | Samsung TXR3079 TV
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
High pitch noise
Hello there, You have to specify where the noise is coming from. Is it coming from the speaker or from the back of the unit. SMPS power supply powering your unit create this kind of noise when some capacitor gone out of their value.
Good Luck.
Jan 26, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
18 Mo old Samsung CXM2785TP made high pitched noise and lost power
The high pitch sound could have been the flyback transformer. check the horzontal output transsitor if is gone the tranfomer is sure to be gone . Tranformers are varying in price are the transistors can also vary you could be looking at around 150.00 plus labour.
Apr 17, 2007 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Televison & Video Logo
1,431 people viewed this question
Top Televison & Video Experts
