Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Jet Dry refill too often
My dishwasher's Jet Dry meter asks for the solution nearly every 5-7 days. I used to go every 4-5 weeks before it requested more. My dishwasher is only about a year old.
  • 185 Answers
Open the plug up and see where your dial is set at if set to high lower it down
Posted on Mar 31, 2008
Jet clean system doesn't work
Did your Jet Clean System used to work, but now rejects the razor and flashes a red indicator that your reservoir is empty when it is not?
The reason is that the liquid level sensor is full of gunk (you don't want to know what the gunk is made of). You can easily clean this yourself and restore normal operation. Here's how:
1. Remove the razor and reservoir. Leave it plugged in.
2. Press the start button and when the holder hits the bottom and stops, immediately pull the plug before it comes back up.
3. Turn the unit over and clean off the gunk you can see with a Q-Tip.
4. Fill the cleaned reservoir beyond the line (almost to the top) with hottest tap water and place it on a towel on your counter.
5. Mix in 1/8 teaspoon of dishwasher detergent. Do not use Dawn or other dish detergent. It must be the type you use in your dishwasher! (Trust me on this).
6. Lower the unit onto the reservoir and let it soak for at least 20 minutes.
7. Hold the reservoir down on the towel by depressing the release buttons and pull and put the cleaning unit in and out of the reservoir 20 or more times to flush out the crud.
8. Refill the reservoir with clean, hot water and do the pull - push trick again many times. Rinse and refill the reservoir with hot water and do this again 2 more times until the water is clear and there is no debris to be seen in the water.
9. Remove the reservoir and allow the cleaner to dry thoroughly. Depending on the humidity where you do this, drying can take from several hours to an entire day. A hair dryer on the part you cleaned with the Q-Tip may help, but time will still be needed.
10. Assemble and try it. It should work like new. If it does not work properly, (mine acted like it was jammed) don't worry, it is likely not completely dry inside. Remove the reservoir and wait for it to completely dry before trying again.
Have fun!
Apr 09, 2014 | Norelco Arcitec Electric Shaver with Jet...
Dishwasher does not dispense jet dry. Is full all the time
If the jet dry dispenser is full, it will last you about 3 or 4 months depending on how often you use the dishwasher
Nov 09, 2011 | Maytag Dishwasher
In my GE dishwasher, the jet-dry in the dispenser turned brown. I emptied it all out and refilled it with clean jet-dry, but a few weeks later it was brown again. I guess somehow dirty water is getting...
Had the same problem, opened up the dishwasher, pulled out the jet dry container and found some kind of nasty growth in it. I honestly have no idea what it is, so of course I took a picture, and then threw the whole thing away._1813.jpg
Jul 17, 2011 | Maytag Dishwasher
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Can I take the bottom part of the dishwaher apart
Mkae sure you are running kitchen hot water faucet before starting dish washer. If not you are getting mostly a cold water wash thru out the cycle. Also make sure the jet dry dispenser is full. Always use the liquid jet dry as the small cubes you can get do not work nearly as well.
Jan 31, 2010 | Kenmore 15762 Dishwasher
My glasses look cloudy. I have used Tang and it
This sounds like mineral deposits. If you don't have one you could have a water softner installed, if you have one already I'd check its salt level or for proper operation. One question to ask yourself is how well do others soaps and such foam up, if little you have hard water. In my opinion Jet Dry and such may assist some but in the end do not remove all of hard water issues. You may have to take your glasses out of the dishwasher beflore the drying cycle and hand dry. In speaking for my household my wife will not allow some of her better glasses into the dishwasher because of this very reason. All of those are hand washed and dried.... we even have a water softnter too.
I hope this might have helped,
Tom
Aug 22, 2009 | Dishwashers
Where do I put the Jet Dry in my Bosch Sensotronic? I bought a house with this dishwasher but no manual. Many thanks!
ON SOAP CUP WITH DOOR OPEN LEFT HAND SIDE IT WILL HAVE A DOOR IT OPENS LIKE A TUPPER WARE BOWL FRONT TO BACK LEFT HAND SIDE OF SOAP CUP LIFT UP AND SLOWLY POUR 3 OZ OF JET DRY OVER DIAL INDICATOR MAKE SURE YOU POUR SLOWLY MAKE SURE YOU CLOSE THE DOOR CLOSE D/W AND REOPEN DOOR THIS BURPS THE DISPENSER. JET DRY IS NOT SOLUBLE IN WARM WATER SO IF YOU SPILL ANY TAKE A RAG AND CLEAN IT UP GOOD ONEC A MONTH YOU REFILL W/ 2 TO 3 OZ
dON
262-893-4840
May 19, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Beaumark jet dry dispenser
Hi puretonedoug,
I'm Harvey the Master Plumber.
Your question is: Beaumark Whisper Wash IV dishwasher jet dry dispenser does not appear to be working ( not using any jet dry) do they plug up or malfunction, if so how do you get it to repair or unplug?
The liquid jet dry dispencer only dispences a few drops in the last rinse. It is not uncommon for it to go a few months before needing refilling so it may not "appear" to be working. Are there spots on your glasses? That's the real test. If there are then just buy the jet dry that comes in a little basket that you hang from the top rack. Replace when it's empty and forget about the auto dispencer. If the glasses are clear then it's working and don't do anything..
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Dishwashers
Model LD1403W1
Are you using a rinse aid like Jet Dry??  All dishwasher manufacturers now require that you use rinse aid for drying dishes at the end of the cycle.
Dec 29, 2007 | LG 24 in. LD-12BW5 Free-standing...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
131 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
