Question about Frigidaire ATF6000ES Front Load Washer
Hi i have a wm12x indesit dial keeps clicking will not reset, changed the timer switch and just cleaned 85 p out of thr filter still keeps clicking. Start lights on permanently no flashing. Last wash came out very hot!!!!!! but hadn't spun well Not yet checked the outlet pipe or pump any ideas
  • randell659 Nov 29, 2008
    Wm12x cycle selector control just keeps going round
  • toulouse21 Mar 01, 2009
    Programme dial continues to click round and not locate, leaving part finished cycle, usally not drained.
    President:
  • 1,294 Answers
You have to check the pump for anything clogging it.
Posted on Jun 16, 2008
SOURCE:
My dial keeps clicking round on my indesit wm12x, have ordered a new part, do you think this is the problem.
I doubt it will solve the problem, as the part you are referring to is a selector switch and not the timer, the problem is more likely to be a faulty control unit.
Nov 19, 2010 | Indesit W 83
Indesit WA6x washing m - dial clicking around...
This sort of problem is usually associated with a faulty control board
If there is a reset point on the timer, then reset it, and try again, if it still does the same thing, then it it is going to be the control board.
Mar 22, 2010 | Washing Machines
Manual for intergrated indesit wm12x washing machine
To obtain the instructions for washer, go to,
WWW.INDESITSERVICE.CO.UK
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Indesit W 123 Front Load Washer
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Regards
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Indesit wm2x
We had similar fault.
Rectified ours by switching off at the mains and put dial to one of the dots. Switched on and it reset.
Good luck
Dec 03, 2008 | Indesit W 123 Front Load Washer
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Help
Refer to your manual and check the pump, there must be a block there.
Jan 20, 2008 | Indesit W 123 Front Load Washer
Filter on indesit washing machine
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Nov 30, 2007 | Washing Machines
Indesit wm12x
look into the filter of the pomp ..clean it and restart the machine
Sep 11, 2007 | Indesit W 123 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
316 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
