Question about Sew Smart Compact Cordless 17390B Sewing Machine
Bobbin how do i thread a drop in bobbin
  • advlsh Mar 23, 2008
    did not work
This is some ******* ****!
Posted on Jun 26, 2008
SOURCE:
Needle thread wrapping around bobbin case.
Hello Crystal, I also have had problems in the past with drop-in bobbins . I had to experiment with different model bobbins . The cause I found was due to the bobbin was not tall enough in the drop-in bobbin case. When sewing , the bobbin would rock in the bobbin case and the top thread would get caught on the bobbin instead of going over the top of the bobbin, causing the rats nest that you described. I would recommend finding a taller bobbin to fit in the bobbin case. There are about five different bobbins that will fit in there, but only one that will work properly. Knowing the exact model number of your machine would be a great help to finding the correct bobbin.
Oct 08, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
Lil sew & sew lss202 bobbin threading?
Drop bobbin in carrier such that the thread and bobbin form "P". When you pull on thread the bobbin unwinds counter clockwise. Lay loose thread in groove on plate coming toward front of machine. Replace cover. Rotate hand wheel towards you to pick up thread. Pull upper and lower threads to rear of machine under presser foot.
Sep 08, 2012 | Michley Lil Sew Mechanical Sewing Machine
How do you thread the bobbin on the model 9805c?
To wind a bobbin, reel on top of the machine, take the thread to the left and go around the small wheel, back to the winder, bobbin on the windere and wind the thread round a few times, slacken the stop motion and wind the bobbin.
If you have a drop in bobbin, hold the bobbin in your left hand, thread on the bottom of the spool, drop the spool in, take the thread through the slot to the left and lay it across the bobbin with enough thread to be pulled through by the needle
Aug 05, 2011 | Singer 3343 Mechanical Sewing Machine
The trouble is the tension with the top thread being straight. I have changed the needle, the thread, the bobbin, oiled the bobbin, cleaned the fuzz. etc.etc.
Is the top thread not pulling down into the fabric? If so I would check the bobbin thread. Is it threaded right? If so you should be able to set the bobbin tension buy holding the thread in you hand, the bobbin case should not fall, when you shake it it should drop a few inches. Thread bobbin in bobbincase. Hold it buy pigtail. Shake it and it should drop about a few inches. You did not say your model number, this will help me, help you . Thanks
Mar 22, 2011 | PfaFF Sewing Machines
Dont know if that its a q or not and cant figure out how to thread the bobbin
Make sure the thread is coming off the bobbin counter-clockwise, hold the end of the thread in your left hand, drop the bobbin into the case, and pull the thread into the slot at the front of the bobbin case by pulling it up and around the bobbin case to the left until you hear a click. That means the thread is in the bobbin tension. Then hold the needle thread in your left hand but don't pull on it; drop the needle into the machine and bring it back up by hand with the balance wheel, and as it comes back up, gently pull on the needle thread. That brings the bobbin thread up through the throat plate in a loop so you can pull it on out, and you're ready to go.
Feb 22, 2011 | Elna Quilter's Dream 6003Q
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
How do you thread thre bottom bobbin on a singer 533?
Drop the bobbin in, holding the the of the thread between your left hand fingers, making sure the bobbin will turn clockwise as you pull on the thread, manually turn the wheel to make the needle go down and up again, as it comes up it will bring the bobbin thread up through the plate hole. There you are, close the plate, good sewing
Aug 10, 2010 | Singer Drop-In Bobbin 758B-28BH Mechanical...
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
My zig zag stitch is distorted on the top side but looks perfect on the underside. I have tried adjusting the tensions and rethreaded the machine, etc.
The bobbin tension sounds too loose. This will help if you have a bobbin case and not a drop in bobbin. Let me know if you have a drop in bobbin:
Setting bobbin case tension:
Put wound bobbin in bobbin case. Thread it in case. Hold the thread and carefully let go of the case only holding bobbin thread. The case should NOT move. Quickly let your hand drop 2-3 inches to let the bobbin case free fall for 2-3 inches, the bobbin case should move slightly then stop. It moves because it let’s a little thread off the bobbin. It should then stop .5"- 2" of thread should release. If so, your bobbin case tension is right. If it’s right then begin to look at your top thread tension. Always Always start with a properly adjusted bobbin case, then adjust your top tension accordingly.
Mar 12, 2009 | Sewing Machines
Threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Jan 11, 2007 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Sew Smart Compact Cordless 17390B Sewing Machine Logo
208 people viewed this question
Top Sew Smart Sewing Machines Experts
krisp525
ray gallant
ray gallant
R.A. Ellis
R.A. Ellis
Are you a Sew Smart Sewing Machine Expert? Answer questions, earn points and help others
