Question about Samsung Digimax D53 Digital Camera
Flash How do we manualy set the flash to stay on? in a lot of our pictures there are dark areas, if the flash was on this would not be happening.As far as I can see the flash is entirely automatic.
    Problem Solver:
  • 5 Answers
I assume you have a digimax D53 as this is where your question is posted. On the top of the camera is two black buttons and the silver button which is the shutter release. One of the black buttons, the one closest to the silver button, is marked with an "M". This button can be pressed while the camera is on and it will allow you to change the settings for flash and for exposure. Suggest that you change it to auto as this is all around the best setting for snapshot type photographs.
Posted on Apr 06, 2008
When you take pictures either on your phone or your camera why do they have a flash at the back when you want to take pictures
If photo you are taking is in dark area , photo will not be seen as to dark area , so if dark , flash fills in .
Mar 16, 2015 | Cameras
Camera want flash sony dsc-h3
If it flashes when you take any photo then you have the flash set to manual override for each shot or you're just shooting in areas too dark for any photos without the flash. Check your flash settings or try a factory default reset from the camera's menu options.
Oct 14, 2014 | Sony Cybershot DSC-H3 Digital Camera
The flash is not working anymore. how can i replace it?
Hi, Check your setting for when you take photo's inside or outside. In dark areas the flash should come on. Check and /or replace batteries. Good luck.
Take a picture in a dark room and see if flash comes on.
Jul 30, 2011 | Fuji FinePix S5000 Digital Camera
Nikon coolpix 4800 - built-in flash may need to be replaced
I have the same camera and have had the lens cover get stuck and it will leave the dark shadow in the pictures like you describe. It doesn't always happen, but when it does I just gently push the lens cover all the way open with my finger.
Mar 05, 2009 | Nikon Coolpix 4800 Digital Camera
Picture in dark condition.
It may be that your subject is too far away. The range of your internal flash is 12 feet if you have the ISO set for Auto, or 23 feet if the ISO is set for to 1000. You may get Normal 0   Normal 0 acceptable results with the ISO set to 1000 without the flash, but you should put the camera on a tripod (the shutter speed could be as low as 1/8 of a second) and use set the zoom for wide angle (the lens lets in almost 8 times the light as it does in maximum telephoto.)
I hope this helps,
Mike
Jan 03, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony dsc730 when i take a picture camera won't flash and picture
the camera doesn't stay on and it won't flash when picture is taken and when it does the picture is too dark
Dec 21, 2008 | Cameras
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Nikon SB 800 fires but pictures reamain dark
make sure your white balance is set to "flash" on both cameras
Oct 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Samsung Digimax D53 Digital Camera Logo
47 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
