Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Belt I'm lost I can't get it over the big pulley
    President:
  • 1,673 Answers
It is hard, but you just have to stretch the belt to go over that pulley.
Posted on Mar 24, 2008
How to tighten pulley on Hoover U6630-900
I'm not sure what you mean by "Common Pulley". There is a flat belt that goes from the motor shaft to the big round pulley on the transmission. There is also a "V" belt that goes from the transmission to the brush roll. You have to be careful how you install the "V" belt because it has a pulley that takes the slack out of the belt when you pull the handle back if you have the lever in "Carpet" position. The belt does not get tight until you pull the handle back which leads many people to believe the belt is too long or the pulley is not working properly.
Jun 04, 2016 | Hoover U6630-900 WindTunnel Bagless...
How do I replace the smaller belt that attaches to the brush
Hello! Follow the steps below to replace the v-belt on your Hoover.
1. Slide flat belt off large pulley.
2. To remove v-belt, slide back of belt over pulley. Then firmly pull on belt and snap it off. Discard used belt.
3. To install new belt (with lettering on outside of belt) slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will pop into place.
4. Insert brush-roll through belt and position belt in groove on brush-roll.
I have also included a link you may visit to view the owner's manual and these instructions.
http://hoover.com/file/509/
Jun 30, 2014 | Hoover U6476-910 WindTunnel Upright Vacuum...
I have a hoover windtunnel turbo power 8000 self propelled model u6660-900. I bought a agitator belt for it that says it's the correct one ( belt #38528-034) according to several websites. But for some...
The belt is correct. You idler pulley is most likely hung up. Look half way between the brushroll and the drive pulley ( that's what the belt wraps around ) there is an idler pulley that puts pressure on the backside of the belt. They are prone to hanging up. A qualified vacuum repair shop can take care of this for you if you can't figure it out.
Oct 20, 2013 | Vacuums
How to install leather belt on Singer treadle sewing machine?
The belt is a round leather belt and is joined by a wire staple. It passes over the pulley on the hand wheel, down through the slot in the table and a slotted plate goes into the table slot with the belt in the plate slot. The belt is than placed against the big pulley, turn the pulley and a lip on the pulley will pick up the belt and feed it into the groove of the pulley - that's it! (If the belt is too long, cut it to the correct length, pierce a new hole in it and feed the staple into the hole).
Apr 01, 2011 | Singer Vacuums
Impossible to change belt--cannot get belt to go over pulley.
first put belt on big round roller then use a flat screw driver to pull it onto the motor shaft
Dec 10, 2009 | Panasonic MC-V7515 Bagged Upright Vacuum
Installing a belt
1. Unplug the vacuum
2. Take the bottom cover over the brush off by removing the 3 screws
3. Switch the brush roll control lever to bare floor
4. Take the roller brush out
5. Put the belt around the small pulley from the motor
6. As you are putting the roller brush back in put the belt around the space on the roller brush - center the belt on that space - THE BELT WILL NOT BE TIGHT BUT THAT'S NORMAL
7. Reinstall the bottom cover with the 3 screws
THE BELT DOES NOT GO AROUND THE SILVER PULLEY CONNECTED TO THE BRUSH ROLL CONTROL LEVER
Dec 27, 2008 | Vacuums
Need drive belt
I'm guessing you have a hoover self propel windtunnel. If that is the case then you should bought the V belt suffix 034 and Flat belt suffix 035. The belt numbers should be listed on the serial tag though.
With most hoover two belt systems there is a pulley that is supposed engage when you recline the machine and this will apply tension to the V belt and tighten the system up so that the brush will spin. If you hold it upside down with the bottom plate off, and release the foot pedal, you should be able to see it happen.
Occasionally that pulley gets stuck and on some newer models they are prone to breaking as well.
Make sure the machine isn't set to floors.
Good Luck
Nov 25, 2008 | Hoover Vacuums
Burning up the big black belt that propells vacuum.
See if you can pick up a nylock nut for the pulley. As long as your nut is a standard thread and not a reverse thread fastener.
nylock nut-homgkn40kjilovpbxhhmhqzq-1-0.jpgThese nuts are self locking.
This product Devcon Plastic Welder is the best plastic repair material I've ever found. Cures in minutes,can be drilled and sanded in hours. Great stuff to fix the hole in the plastic cover.
Apr 20, 2017 | Hoover U6630-900 WindTunnel Bagless...
Put on belt
Take the nozzle of, remove the brush roll, put the new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jun 29, 2008 | Kirby Vacuums
How to install kirby vaccum belts
Take the noozle off of the vac. take out the brush roll and old belt, put the belt over the brush roll and re-instal in the noozle. Turn the big square knob on the front os far as you can, it will lock in that position, then put it back on the vac and lock it down, then turn the knob the other way to release the belt unto the belt pulley.
Feb 20, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
