Question about Dryers
Drum not rolling but I do have heat
Pye2000AYWdrum not rolling, but I do have heat
  • 2 more comments
  • Anonymous Apr 12, 2008
    I just need to know how to put the belt on
  • Anonymous Jun 06, 2008
    Belt is broken and can't figure out how to get a new one on around the drum all the way. Does the motor need to be removed to get a new belt on?
  • johnf52 Aug 01, 2008
    Yes. How do you get a new belt on. All the panels appear to be folded or spot welded!
  • glange6 Nov 30, 2008
    broken belt. how do i get it on? also what should i check to see why it broke?
Drive belt broken
Posted on Mar 22, 2008
My dryer will not heat.
Hight limit thermostat is out or heating element or both dryer will still runs but won't heat!
Dec 13, 2014 | Maytag Dryers
Stopped working today. will not come back on at all. lights come on like it is working, but drum doesnt roll
Check the belt, Remove the bottom kick panel and clean out the lint. turn the drum and see if it is broken or loose.
Jul 07, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
I Have Problem With Dc 2060 error code 10-359 what i do
Open Heat Roll Control Thermistor (the one closer to the middle of the roll).
Jul 01, 2014 | Xerox DocuColor 12 Printer
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
Difference between electrostatic and inkjet printer
This sounds like a "homework" assignment.
An electrostatic printer puts electrical charges onto a drum.
Then, dry "powder" ink is put onto the drum.
The ink sticks only to the charged points.
A piece of paper is rolled against the drum.
The "fuser" heats the paper, and melts the ink into the paper, permanently "fixing" onto the paper.
An ink-jet printer shoots microscopic drops of wet, heated, ink onto the paper.
The ink dries into the paper.
Jan 27, 2011 | Nikon COOLPRINT Thermal Printer
Electric dryer squeels? is it a belt?
could be the belt being "Glazed"from heat,wear,or the drum Roller/Glides on the drum in the front that the dryer rolls on
Oct 26, 2009 | Zanussi TC180W Electric Portable Dryer
Dryer turns on, drum rolls but no heat
the humidity indicator does not show anything and I get no heat and the end of cycle tone dings. Is it just a humidity sensor or is it more like a heating element problem. Vent is clear.
tdrecoll@comcast.net
Jun 04, 2009 | Kenmore Dryers
Dryer drum doesn't sart rolling when it is turned on.
It is not using the start winding in the motor. You might be able to remove the end bell and clean the switch?
Apr 24, 2009 | GE DBSR453EBWW Electric Dryer
Xerox DC12 system failure: code 10-361
I have found the Heating Tube 520 is dead, so the Roll doesn't hot enough. This problem was solved simply - by replacing the Tube...
Feb 11, 2009 | Xerox DocuColor 12 Color Copier
Dryer blowing & rolling but no heat
There should be a little white plug on the front of the dryer. (lower left) Take that out and start the dryer. IF your ignitor is working you will be able to see it turn red through the whole. If you dont change the ignitor. then it will light the burner.
Nov 18, 2008 | Whirlpool Dryers
Dryers Logo
197 people viewed this question
Top Dryers Experts
