Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Help Got a netgear router and belkin cards. Cant get the things running.
    Sergeant:
    Champion:
  • 427 Answers
Well theres your problem (most likely) Netgear and Belkin arent always compatable. Also, try to get the same radio band.
Posted on Mar 23, 2008
Belkin wireless G router incompatible with netgear modem
connect your computer to netgear modem alone and check for the ip address in the computer
(make sure that you have selected "assign ip automatically" in computer)...
to open command prompt type "cmd" and hit enter in run box...
then you can check ip address by typing "ipconfig" in command prompt...
make a note of IP adress or ipV4 address found under the heading "ethernet adapter local area connection"
it might be 192.168.X.X
now connect only the belkinrouter and check for the ip address using the same steps above...
it might be 192.168.2.X
make a note of that...
now compare both the ip addresses if they both have the same value in first three places...that is
192.168.2.... or something like 192.168.1.... or 192.168.0.... then you are facing with double NAT issue...
all that you need to do for that is to change the ip address of belkin router...
if it is 192.168.2.1 change into something like 192.168.15.1...the issue will get resolved....if not you can reset the belkin
router by pressing and holding the reset button for 30 seconds using a toothpick when the power is turned on...
Apr 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a normal small phone connection but the router takes a large er pin connector. what can I do
Ahh, now I understand. Somewhere in the instructions, you need to turn your Belkin into a Wireless Access Point. The Netgear is your MODEM and router. It's the interface to your DSL line. Since it already has a router, the only thing you gain from the Belkin is wireless access.
There shoud be instructions to either turn off the router in the Netgear, or convert the Belkin to a WAP. I'd do the Belkin.
Carl
Mar 17, 2010 | Belkin Wireless-N Wireless Router with...
Drops the internet connection and has to be rebooted at least once a day.
Try to reduce the MTU of the router. If you're on DSL, set the MTU size to 1492, for Cable connection size is 1400 or 1463. You can do it on the router's admin page http://192.168.1.1
May 11, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless connection
i can't connect wireless int
Feb 01, 2009 | NetGear DG834G Router
Wireless internet
Basicly the wireless router needs to be connected into the internet, then you will be able to connect to it. You need to install the card and make sure it works in your device, then connect into the router and it should work fine.
Oct 27, 2008 | NEC MobilePro 900 Handheld
Belkin Notebook card and its wireless access point
In Ideal scenarios, you should just plug in the card in the notebook and it should get installed automatically.
Thanyou may scan for the available networks and you should be able to seethe network of your Netgear router(Assuming that the Netgear you havementioned is wireless capable and configured).
You can connect to the network and it should work fine.
Check this link
Let me know what happens.
Regards,
Sammy
Jul 10, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
I have a prsario 2100 notebook with a Belkin wireless g notebook card I am tryin to connect wireless through netgear router and it is not working
configure the netgear router.
connect the net gear to the internet cable.
see back of the router for information.
and then configure the net gear. and the usermanual of the netgear.
may this help,
melnavz
PS: pls donot rate me if the solution won't help but if this resolve rate me fixya.
Jul 03, 2008 | HP Computers & Internet
Belkin g+ mimo wont work
get a netgear cable modems and routers are based on one of there principles and that is how much packet data can the modem or router handle at a given time some are streaming data like netgear and some are static packet data this could be your hang up
Jun 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Help with netgear rangemax next wireless n router
use the connected pc, its always best to use connected pc, then test using wireless laptops
Oct 18, 2007 | NetGear RANGEMAX WNR834M Router...
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
