Question about Whirlpool GEW9250 Electric Dryer
Dryer thinks clothes are dry but they are not
The sensor thinks that the clothes are dry but then you feel the clothes and they are not dry. it will run for about 15 minutes before it shuts off. all the lights and knobs work. what should i do
  • josh18 Mar 23, 2008
    WHERE IS THE THERMSITOR and what is the part number to order a new one??
    President:
  • Whirlpool Master
  • 2,651 Answers
1 start with claening the sensor strips located just inside the unit itself under the lint filter. pop yourheadinside dryer drum andyoull see 2 metal strips. witha scotchbrite pad, give it ascouruing, to remove any build up form fabric softener / dryer sheets
2 check for good, not kinked or clogged venting
3 replace the thermsitor about 30 bucks.
Posted on Mar 23, 2008
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
When put in sensor dry setting, dryer shuts off in a few minutes before clothes are dry
I'd suggest the dryer "sensor thinks" the clothes are dry, or uses a diffenernt standard, or it's bad. I'd revert to the tried and true method of "time".
Mar 05, 2015 | Amana NED7200TW Electric Dryer
Maytag dryer se1000 runs for 15 minutes then shuts off
Clean your sensors if you have them. They might have junk on them that could be forming a moisture barrier preventing the sensors from feeling the wetness of them clothes. The dryer may think them clothes is dry because it cannot sense wetness.
Oct 05, 2012 | Dryers
Gas dyer not staying on, all the light are flashing
Does your model have sensor strips inside? Wash them with windex to remove any moisture barrier on them. They sense wetness and if they don't feel any wetness they make the control think them clothes is dry and it shuts down the dryer thinkin them clothes is dry.
Jul 09, 2012 | Frigidaire Dryers
My dryer will run for a couple of minutes then shut off we already replaced the heating element
If your dryer has electronic sensors like this:
They might have a coating builtup on them preventing them from feeling the wet clothes.As the wet clothes tumble in the dryer they rub up against these sensor strips. As long a wetness is there the capacitor is dicharged on the controls upstairs and it continues to dry them wet clothes. If junk gets on them sensors no wetness will e felt by them sensors. It is a simple as that. The dryer thinks the clothes is dry because no dampness is being detected so is shuts down thinking all is propah. Get some windex and scrub them sensors good so dampness can be sensed by the two sensors once more and party on!
Jul 23, 2011 | Dryers
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Dryer starts drying and thinks clothes are dry, but they aren't
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Feb 12, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
177 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
