Question about Acer TravelMate 2702WLMi Notebook
Acer Travelmate 270 Memory Upgrade
I'd like to upgrade the memory of my laptop. One of the memory slots is easy to get to (couple of screws to remove on the back of the computer), but I can't find any information about how to access the other memory slot. Any information available?
  • 1 more comment
  • biobms Jul 18, 2008
    So where is the second memory slot?
  • Anonymous Aug 01, 2008
    same problem
  • a_loneranger Jan 13, 2009
    I had the same problem and found the advice given by the Guest on 22nd August 2008 excellent. However, I found it rather easier to remove plastic cover he mentioned in item No3 if the fixing screws around the edge of the base were loosened beforehand. This laptop might be a few years old, but it is quite nifty and with a pair of Kingston1Gb memory modules fitted (it previously had 2x 256Mb) now functions considerable quicker. Sometime back I upgraded the HDD to 100Gb, and that also helped. I am still rather mistified as to why it came with a bluetooth button, but no bluetooth device was fitted. Does anyone know if this is a straight forward upgrade and how it might be fitted?
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Posted on Aug 18, 2009
I've managed to find the other slot. it's under the keyboard.
1st- turn the computer off and unplug all cables.
2nd- open the screen all the way so that it stay parallel to the rest of the notbook.
3rd- remove the plastic cover over the keyboard (the one with the power button, leds and hotkey). it doesn't have any screws. Just remove it gently with a screw driver or a knife.
4th- unscrew the 2 screws that hold the keyboard pad and there it is.... the #!%&/£§£@@ second ram slot.
5th- touch any metal surface to remove all static from your hands
6th- replace the ram
7th- re-screw the keyboard pad
8th- carefuly reinsert the plastic cover
9th- re-plug all cables (or at least the power cable)
10th- turn the computer on, and wait for the system to recognize the new ram and start the Operative System (Windows, Linux, MacOX, etc...)
Note: Acer Travelmate 2702WLMi can run with 2GB (2x1GB) ram. i've used 'DDR-333 PC2700 SODIMM'.
Posted on Aug 22, 2008
    New Friend:
Question to t0msmith:
Hello... I was reading an article about the Acer 270 Travelmate. It came in very useful as I needed to locate the second ram slot.
I have a couple of questions if u dont mind.
How can u upgrade to 2 gigs of ram. Acers own offical website says that its upgradable to 1 gig only and crucial memory say the same?
Do you have an article about upgrading the CPU in detail?
I recently brought a 512mb ram module from mrmemory.co.uk. When i stuck it in the bottom slot it stopped my bios working. Windows XP failed to install. When it finally installed (with the ram out) once i put the ram back in windows blue screened and crashed. I then put it in the second slot under the keyboard and left the standard 256mb ram stick out altogether. Blue screen again.
I used memtest on both sticks seperately. passed numerous times on the 256mb and failed on 512mb. couldnt even do one pass.
The memory I brought was called: AED660SD00-266 ABB 512MB 200p.
Any insight into any of these questions would be greatly appreciated.
Cheers in advance
Tony
I would ask a pro, but... I cant afford it!!
Posted on Jun 12, 2011
  • 34 Answers
Well why don't you just use the one memory slot. If I were you though, I would upgrade more than just the memory. For all it's worth, that PC is worth replacing, very old and outdated. For all of the work involved in replacing the memory card, and such (as well as the expense). I would just get a new one. Plus, installing memory isn't always as easy as inserting a card. Sometimes, the card may not work or worse. If you do relace the memory though, make sure the entire harddrive is backed up externally on multiple media, in case something goes wrong, you don't want to have to redo everything and loose all of your data.
Posted on Mar 22, 2008
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Acer Travelmate 270 Memory Upgrade
HOW TO UPGRADE RAM ON VAIO VPCM121AX LAPTOP
Memory Upgrade for Sony VAIO VPCM121AX Netbook Laptop, the Sony VAIO VPCM121AX Netbook Laptop takes the PC2-6400 DDR2 SDRAM SODIMM 200pin memory Memory Type, and comes installed with 1GB (Removable) of Memory.
You can upgrade your Sony VAIO VPCM121AX Netbook Laptop to up to a maximum of 2GB Memory, the system has 1 Socket to install Memory, already with 1GB (Removable) standard Memory installed.
For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Power off the computer, and unplug it from the power source. Close the computer and turn it over.
Slide off the battery cover and remove the battery.
Locate the memory bay and remove the screws in the cover.
Remove your old RAM board(s) by pushing the metal clips and holding it down and outwards until the RAM board pops up. Then pull it out at a 30-degree angle. (If you only need to add more RAM to your existing RAM and you have enough available empty RAM slots, you will not need to remove the RAM.)
5
Insert the new RAM board into an empty slot at a 30-degree angle until you hear it click. Then push it flat down into the slot.
6
Replace the cover and screw it back in.
Upgrade the Sony VAIO Hard Drive
7
Locate the hard drive bay and remove the screws from the cover. Then slide the cover off.
8
Pull the hard drive out of the bay.
9
Remove the screw securing the hard drive with the magnetic screwdriver.
10
Pull the hard drive out of the bay by the black tab connected to it.
11
Re-insert your new hard drive into the bay and replace the cover.
hope it helps
Jul 15, 2012 | HP Pavilion dv7 Keyboard (483275-001)
Where are the memory slots
On the bottom of the laptop there should be a couple panels with icons. Look for one that looks like a rectangular ghost from Pac-man. That's where the memory slots are.
Feb 23, 2011 | HP 6720s PC Notebook
Can't get computer to recognize memory upgrade
Hello macvalland,
Here's a 12-step memory upgrade procedure from the tigerdirect.com website:
Upgrading Your Memory to Improve Performance
Compiled By Our Editors
http://static.tigerdirect.com/html/installingmemory.html
12 Quick, Easy Steps to Installing Desktop Memory
Increasing your computer’s memory is one of the most powerful ways to improve performance.. The following 12-step guide illustrates how you can install your desktop memory upgrade in 10 minutes or less with the use of a demagnetized screwdriver. But before you begin, make sure you are working in a PC-e environment. If you handle your circuitry improperly you can inflict permanent damage. Your PC’s biggest enemy is static electricity. Static electricity can damage your module and other computer parts. You need to ground yourself to avoid "shocking" your computer. Grounding yourself removes any static electrical charge your body might be carrying. To ground yourself, you can wear antistatic wrist straps or you can do the following: With your computer turned off, touch an unpainted metal part of your computer case with your hand. Plant your feet and do not walk around (because walking can produce static electrical build-up. Now you’re ready to proceed with our 12-step program for installing memory:
1. Make sure your PC has been turned off PC! You’d be surprised how many people forget this common sense first step.
2. Remove all the power cords from your computer system.
3. Remove all the screws that secure your computer case and put them in a place where you can
easily find them..
4. Remove the computer case. Usually you can simply lift the case off once you have removed all the screws. However, if you have difficulty removing the case, consult your computer’s user manual.
5. Locate the memory slots on your motherboard. In some PCs you will find then beneath a power supply or drive. If so, you may need to remove some additional parts in order to gain access.
6. If you need the replace an existing memory module, undo the module clamps and gently lift the memory module out of the slot.
7. Take your memory module out of its anti-static bag and hold it gently by the edges. Line up the notch on the bottom of your new memory module with the empty memory slot and press the new module down with your thumbs until the pins rest snugly inside the slot. You may have to exert some pressure! When will hear a click when the memory module is installed correctly.
8. Secure the new memory module by attaching the module clamps.
9. Put the computer case back on.
10. Replace the case screws to secure the case.
11. Attach your power cord.
12. Now that your new memory has been installed, turn on your computer!
Once your memory has been physically installed, the computer must install it electronically. Once your PC is turned on, you may have to go into computer BIOS to enable your system to detect the new RAM you have just installed. Refer to your computer us
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | Acer Aspire 5315 Notebook
How to install RAM?
You can get detailed description of how to install the ram in the below link
http://www.helpwithpcs.com/upgrading/install-laptop-memory.htm
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 05, 2009 | Toshiba Tecra M7 Tablet PC
Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
How do I install upgraded memory sticks?
Usually, you just remove a panel from the bottom of your laptop and there should be a couple of slots. all you then do is gently but firmly push you memory into the slot and when do,replace the panel and turn the computer on and all should be done
Dec 27, 2008 | Dell Latitude D600 Notebook
DDR2 upgrade
should be easy on bootem under one of them panels in middle usally do u wann add 1 gb more
Jan 07, 2008 | Medion md40298 Notebook
Memory installation instructions
The memory cover is on the bottom of the laptop it is held in place with a screw or/screws, and may or may not have small holding tabs which keep the cover in place. when you remove the screw pop the cover off the bottom of the laptop and you will find your memory located there. BPCS
Dec 27, 2007 | Computers & Internet
Memory upgrade
First thin you have to remember is if you want to have to memories in parallel...Then the new one should be of the same size and frequency(ex:133Mhz,533Mhz..etc.,)Then folow these steps:
  1. Turn off the computer and remove all power cords from the computer system.
  2. Locate the panel used for access to the memory modules. This is generally located on the bottom of the laptop computer. Refer to your laptop instruction manuals for locating the panel.
  3. Remove any screws that the panel in place and place somewhere safe to prevent losing it.
  4. Remove the panel from the laptop and set aside.
  5. If replacing or upgrading an existing memory module, remove the memory modules by undoing and module clamps and gently lifting the edge of the module to a 45-degree angle and then pulling the module out of the slot.
  6. Align the notch of the memory module with that of the memory slot and gently insert the module into the slot at a 45-degree angle.
  7. Once all the pins are in the slot, gently rotate the module down flat until the clamps lock into the module into place.
  8. Replace the memory access panel onto the laptop computer.
  9. Replace any screws or fasteners that hold the panel in place.
  10. Replace the power cord and power up your computer system.
Oct 13, 2007 | Acer Aspire 3610 Notebook
Memory
To get at some parts takes some doing, but the AVERATEC 4200 AV4265-EH1 is user upgradable. The 80GB hard drive and one of the 256MB memory slots sit under a large bottom panel held in place by seven small screws. Removing two additional screws frees the hard drive. To reach the second RAM slot, you have to loosen one additional screw (labeled "D" in the manual but not on the notebook) inside the bottom compartment, pop out keyboard's four top latches, and lift it off. The RAM slot, the only exposed component beneath the keyboard, is easy to find. Another 256mb run both will surfice.
Sep 22, 2007 | Averatec 4200 Notebook
Acer TravelMate 2702WLMi Notebook Logo
2,081 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
