Question about ASUS P4S800D-X Motherboard
Just bought new memory still overcloking failed
I just bought new memory corsair 1gb DDR vs1gb400c3/eug and still have that overclocking failed. Everything is new in my computer now still haven problem. What else can I do to solve my problem. It takes 3;10 from start up to overclocking failed to my window page. How long does it usually take for it to boot up? I'm get ready to pull out my hair with this problem. Any solution?
    Genius:
  • 1,913 Answers
Hi
set your bios jumper setting clear it.
load default bios setup take away the cmos cell for 15 minutes and then put it in case.
after 15 minutes your problem is solved
best og luck.
notify me this solution is right or rong
Posted on Mar 23, 2008
How do you know when a memory stick is single-bank? I want to upgrade my A7V8X-X with 3 Gs, but I keep getting confuse how to determent what is single-bank! Is there a specific code in the product...
This is the memory spec for your motherboard...
3 x DDR DIMM Sockets
Max. 3 GB unbuffered PC2100 / PC1600 non-ECC SDRAM Memory (PC3200 Max. to 2 banks only / PC2700 Max to 4 banks only)
Part of the memory spec will tell you if it is single sided (memory chips only on one side of board)
Double sided is memory chips on both sides of the board....Some systems will not work with double sided memory...
Feb 10, 2011 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
System failed to boot when installing additional 2X 1GB RAMs.
you need to place them on your motherboard where the memory is installed. Place in the order of one new, one old, one new, one old stick. that way they run in dual channel.
Oct 07, 2008 | ASUS M2N-E SLi Motherboard
Cant Start Up
Hi
start with removing the added ram try starting up, if it doesn\t start up does it beep?
if noting happens remove all the ram, the computer should definitely beep now.
Add only the original memory and try starting up you should get picture.
This seems to be a old problem and if you don\t need assistance in solving it. It would be great if you would share to the world how you fixed your problem so other users can benefit from your experience.
Thank you, Ekse
Sep 28, 2008 | Corsair Memory Value Select 1GB PC2700 DDR...
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
2 GB or more RAM is not functional
try maybe theres a problem in memory compatibility...dude first try to put same memory card brand and specs
Sep 01, 2008 | MSI K8N Neo4-F Motherboard
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
Memory
That memory you have listed should work with your board. Matched memory should be bought inpairs. Check your manual at pg. 1-19. There is the QVL list of teaded memory
Hans a great day!
Mar 22, 2008 | ASUS P4S800D-X Motherboard
Need to find timing and voltage on my memory to make correction to stop overclocking failed, need help please.
dragon512, sorry boss. You have posted at least 4 problems & you never took the time to vote any of your post. You get a free answers & just blow off people.
ASUS P4S800D-X Motherboard Logo
165 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
