Car Audio System
Im hoping maybe someone on here knows something about automobile audio systems (amplifier and subwoofers). lately my car has been doing something weird to my system, when i accelerate, i lose almost all of my bass. then when i press my brakes, my bass comes back full force. can someone help me please?
Yo the main amp wire might not be thick enough so when drivin its not drawin enough power give me some more info i maybe able to help more
Posted on Mar 22, 2008
SOURCE:
What are some best cheapest bass amp under 500$?
'Best' and 'Cheapest' are seldom in the same category, but have a read of these links.
12 Best Subwoofer Amplifiers for Your Car or Truck - BestProducts.com
www.bestproducts.com/cars/parts/g662/subwoofer-amplifiers-for-your-car/
  1. Cached
  2. Similar
Jul 19, 2016 - If you want big bass, choosing the right subwoofer is only half the battle. Be the loudest car on the block with the help of these new mono amplifiers for your car or truck. ... 14 Best Rubber Floor Mats for Your Car or Truck.
Best Car Amplifier 2016 ' Top Rated Auto Amplifiers - CarAudioNow
https://www.caraudionow.com/best-car-amplifiers/
  1. Cached
Looking for the Best Car Amplifier of 2016? ... And if you are going to add a subwoofer, a monoblock amp is an absolute necessity. ..... Two-channel A/B ZRX516.2, 500 watts; Four-channel A/B ZRX616.4, 600 watts; Four-channel ... (PCBs) that can perform under the most rigid and extreme conditions attesting to the brand's ...
Bass Packages Under $500 at Crutchfield.com
www.crutchfield.com > ... > Car Audio, Video & GPS > Car Subwoofers & Boxes
  1. Cached
Under $500 - Shop for Bass Packages with the help of real A/V experts. ... package includes Magna Bass MB212P mono amplifier (250 watts x 1 at 4 ohms) and ...
Can you guys recommend me a combo amp under $500? ' TalkBass.com
https://www.talkbass.com > ... > General Forums [BG] > Amps and Cabs [BG]
  1. Cached
Jan 19, 2012 - Hey guys, I'm currently in middleschool and I need a new amp thats preferably 400-500 watts, but under $500. We currently have a bassist, ...
Need good advice on a sub+amp combo, $500ish budget - Car Audio ...
www.caraudio.com > Forum > Car Audio Discussion > Subwoofers
  1. Cached
  2. Similar
Oct 13, 2012 - 12 posts - ‎1 author I'm new to both the forum and somewhat new to car audio in general so please excuse any ... So i need a great sub and amp to complement them for around $500. ..... other subs for under 200 bucks id rther have over type r
World Record Budget Build w/ Drew Wesley's $500 Car Audio System ...
z? 2:32 https://www.youtube.com/watch?v=NOatL_DzZL0
  1. Similar
Oct 3, 2013 - Uploaded by EXOabigdeal World Record Budget Build w/ Drew Wesley's $500 Car Audio System ' 4 12" VVME Subs & Bass Amps ...
Top 10 Best Car Amplifiers To Buy for 2016 - MyCarNeedsThis
mycarneedsthis.com/todays-best-car-amplifiers/
  1. Cached
Whether you're looking for an amplifier to power your entire cars component speaker ... power outputs come in 3 settings (of 800 watts, 500 wats, and 300 watts ). ... Rockford Fosgate R750-10 Class D 4-Channel Subwoofer Amplifier ... Talk about power when it comes to getting some serious knocking under the trunk.
Oct 30, 2016 | Car Audio & Video
Could i wire my audiobahn Eternal subwoofers to my surround sound system?
is your subwoofer self amplified? if it has, you can connect it through audio sub output and in put to your self amplified subwoofer.. if it is not self amplified, you can still connect it but be sure it ca drive your subwoofer, it depends on RMS or watts of the original sub of the srround..or you can have a seperate amplifier only for your subwoofer. "Audio out - Audio in"
Aug 10, 2012 | AudioBahn AWES12P Car Subwoofer
The protect light is coming on but before it comes on my subwoofer flexs back and forth rapdly then it stops and the light comes on im pretty sure it has something to do with the rca cables
This is a sign that the subwoofers are wired at at ohm level that the amp can't handle, check on the amp to see at what ohm it is stable...this site will help..
http://www.crutchfield.com/S-zYDEpBMncDL/learn/learningcenter/car/subwoofers_wiring.html
Aug 21, 2011 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Output of amplifier gives wired noises no Bass
check how your wires are run from the radio to the amp try to split them up and see if the noise still comes. buy some new rcas this will help with noise. make sure you have tru connections
Mar 10, 2010 | Jl Audio 1000/1 Car Audio Amplifier
POWER ISSUES
Recomend installing a capacitor, this will control voltage drop and reduce heat. The new battery should help, but it also may be that the amps final circuts could be wearing out, and no longer able to handle the load of the sub.
Sep 28, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Audio for my car
IMO, I suggest for head unit go for pioneer that also goes to the seps and mid speaker. for subs and amp try getting a kicker.
May 27, 2009 | Car Audio & Video
Air conditioning condensation and speakers
Check for audio from the radio. Hook up some test speakers and make sure the radio is working. If not then your last stage audio amplifier might be defective. also test you after-market amp by injecting audio into in and see if it is still functioning. If the radio is not working and the after-market amp is then the radio is the problem and its internal amplifier will have to be replaced. If the radio works and the after-market amp does not then the after-market amp will have to be repaired. I would suggest getting this testing done by a professional auto-sound shop, to make sure the proper testing is done.
I hope this helps,
Shuttle83
Aug 09, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Hi, im jason!
Any car Amp rated around 200watts, 4ohms... (bridged)
If you don`t stick to these ratings you can damage speaker...
Post From Tricky...
Jun 16, 2008 | Alpine MRV-1507 Car Audio Amplifier
Wrong connection continuation
If you're installing this in a vehicle with a 12 volt charging system (most automobiles are 12v), I think the batteries may be dead in your multimeter. You shouldn't read anything over ~15v.
When you measure this again, place the black lead on the ground terminal of the amp.
Dec 16, 2007 | Jl Audio 300/4 Car Audio Amplifier
41 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
