Question about Panasonic DMR-EZ47V DVD Recorder/VCR
DVD copying I am trying to copy from VHS to DVD with a VHS-DVD recorder combo. Along the line I always get the message the space on the DVD disc is not enough. I am using standard DVD-RW, 120 min, 4.7GB discs. How do I get around this problem? Are there DVDs with larger storage space?
  • David Adjetey Mar 23, 2008
    Thanks a million for your help, JohnKenn. What I can't understand is; why is that a 70min VHS video cannot be recorded unto a 120 minute DVD? Is it because I have set the recording type to the highest and fastest quality?
  • 47 Answers
The 120 minutes that you see on the DVD cover is the amount of space you would get in the default recording bit-rate. You can increase the bit-rate on this unit by selecting the recording mode before you begin recording. The options are:
XP - 1 hour, highest bit-rate, least compression, best picture, larger file-size.
SP - 2 hour, default bit-rate, standard compression, good picture, average file-size.
LP - 4 hour, lower bit-rate but double horizontal resolution of LP mode on other units, higher compression, good picture.
EP - 6 or 8 hours (depending on setup options), low bit-rate, high compression, below average picture, small file size.
Because you cannot do VBR recordings durring dubbing, you will have to either:
-set the record mode to SP and have 50 minutes of left-over space, or
-leave it set to XP mode and cut 10 minutes off of the VHS.
Posted on Apr 05, 2008
  • 34 Answers
There are double layer DVD's that they make which usually have about 2x the memory. check to see if your DVD recorder supports these types of DVD's. You could also just divide your media on to two sides of a double sided DVD (each side has the mirror look and you can record onto both sides)(still the same disc) or you could record on to multiple DVD's (may be inconvenient but is still an option). Also, you could reduce the recording quality just a bit so that it is not noticable when you watch it but it still uses less space on the disk. I would tell you how to do these things but I have no experience with the individual model that you have.
Posted on Mar 22, 2008
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
I have a Toshiba DVD/VCR combo and I want to know if i can record a VHS onto a blank DVD disc ?
It all depends on the model of DVD/VCR Combo and what VHS you want to copy.
Pre Recorded VHS are copyright protected so the system won't let you copy them.
May 29, 2011 | Toshiba Televison & Video
I have converted some NTSC vhs to PAL dvd, when i play them on my LG DVD player, it says disc error
U must copy NTSC to NTSC.PAL to PAL.Check ur DVD recorder/VCR combo menu set up regions auto, if it have it.Will play all regions DVD discs.
Mar 26, 2010 | LG RC897T DVD Recorder/VCR Combo
I WAS COPYING A VHS TO A DVD..WHEN FINISHED A MESSAGE APPEARED SAYING BIT WAS COPYING FILE INFO..THIS MESSAGE ALWAYS APPEARS AT THE END OF COPYING..THIS TIME IT DIDN'T GO OFF. AFTER ABOUT 1/2 HOUR, I...
One of two things have happened.
1) Either it's system board has has gone bad or
2) The dvd laser block has gone bad.
May cost more to service it than to purchase a new one?
Call around to a trusted service shop to get an estimate of repair.
Feb 03, 2010 | GoVideo Go Video DVD/VCR Combo
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Copying VHS tape to DVD
Hi.
I'm sorry, but according to zenith xbv323 VCR/DVD combo user's manual page 24 you can ONLY copy DVD to VCR and not the other way
Feb 26, 2009 | Philips Magnavox DVD/VCR Dual Player
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording from vhs to dvd
As long as you've got the DVD recorder set to the correct "channel" I can't see why it won't work. Why don't you just try it out on a DVD-RW first ? Use RCA cables from the VCR "OUT",  to the DVD recorders "IN" sockets and you'll be okay. If for some unknown reason it doesn't copy you haven't used a good disc. Probably won't copy anything with Macrovision(or other copy protection) though.
Sep 05, 2008 | Sony RDR-VX515 DVD Recorder/VCR
Copying vhs to dvd
The write-protect tab on the cartridge is set to "PROTECT" or the disc is protected witht the "DVD Management" settings.
Some video tapes on the market(including rental videos) are copy-protected to prevent illegal reproductions. Copy-protected video tapes cannot be properly recorded.
You cannot use the copying function when the FUNCTIONS window, the Scheduled Recording List screen, etc. are displayed.
I hope this information can be of some help to you all. Ms Tanya 2/12/08 3:54AM CST.
Jan 30, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
137 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
