Question about Bosch 24 in. SHV55M03GB Built-In Dishwasher
Bosch shv55mo3gb Keeps stopping during cycle, when open door the little tap light is on meaning trouble with water, checked supply vavle is on, checked filters and no kinks in hose, if i turn the water supply valve on and off then sometimes you can here the water flow through and it will work again, onlt 13 months old??
Use this link then click on insruction manual download type in the model number remember 0 is a number.I know that sounds condesending but i forgot. I used the manual with the ending aus.
http://www.bshappliancecare.com/Bosch/Bosch_dishwasher_manual.html
Posted on Jul 01, 2008
Bosch was28440au logixx 8
What happens when you select the spin, or drain cycle? Does the washer drain the water and commence with the cycle? If the water does not drain then the door will not unlock on it's own. The pull cord should open the door regardless. If the water is not draining, remove the lower right access panel and check the strainer for excess debris. Pleazer Appliance...
Apr 13, 2014 | Washing Machines
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
F8 flashing unit will not cycle gets water then starts beeping
F8 - this code is indicated that there is your dishwasher is having problems detecting the correct water level. Often this results from an insufficient amount of water entering the dishwasher during a cycle - so the water supply is probably ok but check it as F6 (F6 means that the dishwasher is unable to fill with water. Ensure that the dishwashers water supply is turned on (double check the tap valve to make sure its open). As above, also make sure that the inlet water hose is not obstructed, kinked or twisted), just in case.
Occasionally the water level sensor might misread if there a too many bubbles in the dishwasher (i.e. if you put washing-up liquid in the machine, etc).
Otherwise your machine may be having an issue with water pressure, possibly caused by a faulty water pump.
Hope this helps.
Jun 03, 2011 | Bosch Dishwashers
My shv55mo3gb has stopped heating the water but completes the cycle. apart from the element what else could it be please. jim
I think you already answered the question. Have you tested the element for resistance/continuity?
If you checked the element and the wash programs are running though normally, then it can really only be a wiring fault.
Oct 14, 2010 | Bosch Dishwashers
Dishwasher keeps stopping, halway thro cycle, or at anytime during cycle, it will start back up if door is opened and shut, or if front panel is tapped
It's almost definitely a loose connection in the wiring to the cut-off switch in the door catch or to the control panel. Vibration from the machine during operation is probably causing it to lose contact, and when you tap the panel or close the door it makes contact again.
The only way to check this is to remove the control panel and/or the main door panel. You'll need a T20 T-Star screwdriver to remove the panel.
If you've got the tool and are confident enough to have a go, post back and I'll give you some tips on removing the panels and what/where to check.. Otherwise you're going to need an Engineer or a competent friend.
I could do it if you're near Bristol . . . England.
Oct 11, 2010 | Bosch 24 in. SGS43C12 Classixx...
On the regular cycle for Bosch Nexxt 500 series, during the warm or hot cycle the washer interrupts the cycle with error code "E02" and stops washing . . . how can I fix this? I've made sure the door is...
If the unit is fed by both hot and cold it is possible that the single hot valve or one side of the double cold valve is not operating. Maybe a silly question but could one of the taps have been turned off inadvertently?
The other possibilty is that the pump filter or outlet hoses are blocked and the machine cannot empty the detergent water ready to refill with clean rinse water. To test the cold valve put the w/m on a cold wash cycle, open the drawer and check the water flow. To test the other part of the same valve, put the w/m on the rinse cycle that would take the softener or a wash cycle with prewash. Test hot valve by selecting the hottest cycle usually 90 or 95 degrees, check water flow thru drawer. Hope this helps.
Jul 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Bosch Nexxt 500 is on rinse cycle, won't drain the water or spin
Hi
I would check two things that might cause this problem .
1. there is small palstic capsule that comes out from the tank and has thin rubber pipe that goes to the electric tap. the purpuse of the tube is to send signale to the tap to close the water , actually the tap has a sensor that sence the change in presure when the water tank is filled . check this capsule and make sure that its clean.
2.looks like the cycle of washing hasn't started or started but hasn't pass the stage of heating the water . that means there is some problem with the heater that lies in the buttom of the tank . make sure all wires attached properly .
try run whashing program of cold water .
consider replacing the heater .
hope it helps
goodluck
May 25, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Dishwasher
Hi, it sounds like there is no watewr supply to the machine. Try turning the valve closed, and then opening it again. If that doesn't work, turn off the water and disconnect the supply hose. Then, with a bucket handy, turn the water back on slightly to see if water is coming through the end of the hose to the machine. Also check the gauze inlet filter for blockage with grit.
Let me know how you get on before rating the solution!
Thanks, D.
Jul 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
"Check Water Tap" error
rinse valve possibly open circuit or external water pressure low
Feb 08, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch 24 in. SHV55M03GB Built-In Dishwasher Logo
1,608 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
