D Drive stopped working
My D Drive has stopped working, it simply doesn`t recognise any disks, when I click on the drive it says "insert Disk in D Drive"
The system info says the device is working properly, I have tried uninstalling and re-installing but still nothing. Can anyone suggest anything. Thanks
  • old west Nov 13, 2008
    My combo cd/dvd drive on my acer laptop will read files saved on cd, but if I try to save new files, it says "load disk in drive" and also when I checked its status, it says "working properly".
  • Anonymous Dec 02, 2008
    I have the same problem
    need help
Hi luggina so u have a problem with ur cd rom did u check with ur cd ar they clean if that so try cleaning ur optical lens just open the door of ur cd rom drive take a tissue hold the end of it take spirit or a cleaner and just clean on ur optic then check if it still have apro u may check with ur hardware tech
Posted on Mar 23, 2008
I have a sony vaio VGC-LN1M, I insert a disk in to drive sd/mmc [d:] it then still asks me to insert a disk .
it usually means that the sd/mmc card is not formatted with a file system recognised by windows, or is not formatted at all, or is faulty. however, sd/mmc is not a disk, so it sounds like either you are confused, or your optical drive is using the same drive letter as the mmc or sd port. If that is so, right-click on my computer, go to manage computer - then disk management. select the optical drive right click and select change drive letter and paths. now pick an un-used drive letter for the optical drive and apply the change. you may need to restart the computer. then the optical drive should work.
You haven't specified what version of windows you are using, but the action is roughly the same.
Aug 15, 2014 | Computers & Internet
When I connect it to my laptop (or ANY other computer/laptop) the blue light on the external hardrive turns on and I can feel that it is working, but it simply doesnt get read, the computers dont recognise...
Open the enclosure.
Separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a 'slave' disk-drive in a desktop computer, and see if you can read the files.
If not, search online for a professional 'data recovery service' -- for a FEE, they can repair a disk-drive just long-enough to copy your files onto a new disk-drive.
Oct 26, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
DVD drive on Asus a9rp not being recognised. Selected in the bios set up. Just stopped working. Yellow activity light comes on for a while when a disk is inserted but disk not recognised on the screen
Your CD drive unable to read the CD inserted in the drive.So please checkout the lense or check the data cable which connected to cd drive is working properly or any fault is there.
Aug 19, 2010 | ASUS A9RP Notebook
I am not recognising kigston data traveller
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
NOTE Formating the USB flash drive will delete your data.
May 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Removeable Disk Not Recognised. I have my USB labelled SONY USB 2.0 I GB. once I plug it on my computer never recognised. So am asking you to get better solutions, Regards, charles
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 12, 2009 | Sony Electronics - Others
Computer does not seem to recognise disc. I keep
Hello !
Either your disk or disk drive is problematic.
Try your disk in another PC to test. If the disk works, your CD drive is faulty. Try another disk in your computer's drive. If the disk doesn't work, you have confirmed that the drive is faulty.
If the drive is a problem, I would suggest to purchase a disk head cleaner, first. Then, if the drive is still a problem, it would need replacing.
Hope this helps.
Sep 10, 2009 | Lexmark Office Equipment & Supplies
My cd drive doesn't recognise the disk inserted
Can you see the information on the CD/DVD from Windows Explorer? (NOT Internet Explorer). Some CD's/DVD's just won't recognize correctly from Auto Play. If you can see what's on the disk (in Windows Explorer) try double clicking the Setup.exe or Run.exe from there and see if it loads. I have the same problem on some of mine.
Jun 09, 2009 | Acer Computers & Internet
Insert a new disk
Try connecting it on a different system, if it is not getting recognised you will need to format the drive.
Jan 27, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
USB flash disk not working
Assuming you are using a Cruzer Micro Drive with U3 Smart, things can be a little confusing because the drive actually shows up as two independent devices. When you insert the drive, there should be two devices showing up in your list of drives. One of them is installed as a CD Rom Drive and the other one is a Removable Drive. If you double click on the CD Rom Drive instead of the Removable Drive and you don't have any U3 applications mapped to the CD Rom Drive, then you'll get an insert disk message because Windows thinks that the CD Rom Drive is empty. Just use the Removable Drive if you want to simply install and transfer files.
Jan 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
287 people viewed this question
David Payne
David Payne
