Question about Canon PowerShot S2 IS Digital Camera
Canon Power Shot S2 IS Digital camera does not turn on
My S2 IS does not turn on. I changed the batteries and cleaned battery contacts. The batteries are put the right way. It does not turn on. Its dead. What else do I do?? Do you suggest some good camera repair stores. I guess Ritz charges about $180.00 to fix it.
Thanks
Nair
  • 1 more comment
  • Anonymous May 20, 2008
    same problem here
  • Anonymous May 26, 2008
    I'm trying to figure out the same thing, it's really upsetting me.
  • Anonymous May 31, 2008
    I have basically the same problem because regardless if I put in new alkaline batteries or newly charged ones my camera may will only take a couple of pictures before I get the "Recharge Batteries" message. I have really enjoyed my camera especially the 12X optical zoom but I don't want to have to pay an arm and a leg to get it repaired.
    Novelist:
  • 130 Answers
Call Canon tech support. It's free support and you may end up coming out cheaper by upgrading your camera through their Canon Loyalty program than having it repaired.
Posted on May 30, 2008
Have a 4-5 yr old Canon S2 IS PowerShot A75 Digital Camera. The batteries are new &/or charged but the camera won't always work reliably - says to change batres. but if I just open the bat. door...
Sometimes, the lower contacts get bent downward after years of use, causing the batteries to ride low in the compartment, and thus making poor contact when the battery door is closed. Try lifting/bending these interior battery contacts upward, so that the batteries ride higher when inserted.
Oct 29, 2011 | Canon PowerShot S2 IS Digital Camera
Canon Powershot S2 IS Digital Canera says to change the batteries even with new batteries in
Check that your battery terminals are clean and that none of them are loose. You may also need to change an internal battery, the one that saves the date & time.
Apr 10, 2010 | Canon PowerShot S2 IS Digital Camera
I have a Canon PowerShot S2IS that gives me a black screen and a "change batteries" message even with new batteries. Is there a way to re-set or re-boot the camera?
Try cleaning the battery compartment contacts with a cotton swab "dampened" in rubbing alcohol. Also clean the battery contacts and the charging station the same way. Thanks, Dana
Nov 22, 2009 | Canon PowerShot S2 IS Digital Camera
Camera clicks continuously when turned on but doesn't work
The problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem is frequently due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Sep 11, 2009 | Canon PowerShot S2 IS Digital Camera
Canon power shot S2 IS 5 mega pix camera it just shows a black sc
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S2".
Best regards,
May 07, 2009 | Canon PowerShot S2 IS Digital Camera
When I put brand new batteries, it says "Change Batteries"
Use a Q-tip with alcohol to clean all the batter contacts (battery cover and inside the battery compartment), and a small hook into the compartment to pull up the contacts a little bit up. The idea is to make the batteries connect properly.
Use NiMh rechargeable batteries or Alkaline batteries, don’t use other Dry batteries, which are not designed for digital camera.
Apr 10, 2009 | Canon PowerShot S1 IS Digital Camera
My Canon power shot S2 IS does not detect the batteries
There is a battery charge level sensor in the DC/DC internal converter board.
It seems that just started to fail such board.
You can try with other brand or type of AA batteries.
If still you have the same problem, you will need to have replaced the DC/DC converter board on your camera. This means a Camera repair shop service on it.
Best regards,
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
View window is black
There is a temporary fix that works sometimes but eventually it will stop working alltogether. If canon can't help, might try this:
<http://cgi.ebay.com/Repair-blank-black-pictures-S2IS-canon-powershot-S2-IS_W0QQitemZ300293064869QQcmdZViewItemQQptZDigital_Cameras?hash=item300293064869&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50>
Jun 28, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
155 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
