Question about Samsung V25 XVC 2800 Notebook
Samsung v25 shutdown
When I switch off my laptop it goes right down to "Saving your Settings" abut does not shut off and I have to crash the laptopa and reboot before I can then switch off an you offer any explanation please
    Guru:
  • 377 Answers
Hi dear
Do not complete the following procedure unless you are very familiar with internal computer hardware removal and installation. The hardware components in a computer are very sensitive to static electricity. For information about the correct handling of computer components, contact your computer manufacturer. 1. Shut down your computer, and then remove all the Peripheral Component Interconnect (PCI) devices. 2. Restart your computer. • If Windows starts successfully, shut down your computer, and then reinstall the PCI devices one at a time. Start Windows after the installation of each device. When you install a device that causes the issue that is described in the "Symptoms" section, remove that device, and then continue to install the other PCI devices. • If Windows does not start successfully, remove one or more of the memory modules that are installed in your computer. Leave sufficient RAM for your computer to start and run Windows XP.
Note Windows XP requires 128 megabytes (MB) RAM. The minimum is 64 MB and the maximum is 4 gigabytes (GB).
For example, if two 256-MB memory modules are installed in your computer, remove one of the memory modules. If Windows starts successfully, shut down the computer, and then reinstall the RAM modules one at a time. Start Windows after the installation of each RAM module. When you install a module that causes the issue that is described in the "Symptoms" section, remove that module, and then continue to install the other RAM modules. 3. Determine if the PCI devices in your computer are compatible with Windows XP. To do this, visit the following Microsoft Hardware Compatibility List (HCL) Web site: http://www.microsoft.com/whdc/hcl/default.mspx
Posted on Mar 22, 2008
Why does my music stop when i close the cover of my samsung galaxy s3 tab?
You have settings set to shut down the unit when the cover closes. You need to go into the settings and find the power saving settings and the startup/shutdown settings. Then disable that setting that shuts down the unit when the lid is closed.
Dec 29, 2017 | Samsung Cell Phones
My samsung Laptop screen too dark when used with battery
It will because when you unplug the Power cable, it will automatically switch battery mode. When in battery mode it also activates a kind of Power saving mode by default. Thats why it seems dark. Now if still want to brightness then remove adjust the brightness level while the laptop is on Battery Mode but i must tell you, your battery backup won't last too long.
May 04, 2010 | Samsung V25 XVC 2800 Notebook
Acer laptop aspire 4710z config my notebook have problem
Dear, first make it format again & make it clear that not a single file will lose. it will definately help you.
Bhaiko_bhai
Mar 02, 2009 | Acer Aspire 4720 Notebook
Samsung v25
Try to diagnose the problem first...
1. Turn it On your Laptop
2. If you have CRT Monitor? connect it to your Laptop if they have screen appears.
3. If they have display your LCD have a problem.
Aug 09, 2008 | Samsung V25 XVC 2800 Notebook
There could be an issue with the user accounts logins. This could be corruption in the OS when you installed it or a clashing driver . I would recommend you reinstall the Operating System with the Disks and before you start installing the drivers try to shut down and see if it shuts down properly . If it does then you know the Operating system and hardware is all fine and can continue installing one driver at a time and shutdown and restarting, continue doing this until you see which driver is causing a confict with your system. I have had a problem similar to this but it was some windows updates pack that I had done one time and had to reinstall windows too and do one by one. Hope my answer gets you closer to a solution.
Aug 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Samsung V25 fan replacement
It may not be the fan, I have a V25 and it was the motherboard, it wouldnt power the fans anymore when the CPU required it so would crash lots.
If the fans twitch or run for a second or two when you first turn the laptop on then it's the motherboard that is faulty.
Careful with the monitor to motherboard plug as I damaged mine and the screen is now a permanent shade of blue.
Jun 25, 2008 | Samsung V25 XVC 2800 Notebook
Viao PCG-GRX650 won't shut down fully
DaveBaker,
Here are a couple of tips that I've collected that may address your problem.
Go to start>run>then type in "cmd" without the quotes. this will bring up the command prompt. next type in the following command: "shutdown -s" without the quotes again. This should tell your system to shutdown your computer entirely.
Next
Try doing this. Hold down "ctrl" and left click "shutdown". This skips some windows XP shutdown procedure and should do the trick.
And, finally
http://support.microsoft.com/?kbid=831431
You cannot log off, restart, or shut down your Windows XP-based computer This article talks about an issue with Norton 2003 incompatibility.
Would appreciate any feedback as to which of these worked for you.
Thanks much!
Ron-
Nov 09, 2007 | Computers & Internet
Samsung v25 won't boot up
this is os or motherboard problem, reinstall the os
Nov 05, 2007 | Samsung V25 XVC 2800 Notebook
Samsung V25 XVC 2800 Notebook Logo
94 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
