Question about Whirlpool AWZ410 Front Load Washer/Dryer
Door problem hi,my waching machin no opening.i cannot unlock.my londry in side. help my.
Use little bit force using screwdriver at the tip of door.u just calm urself & read the mannual carefully and systematically,ur lifepartner/family member company would make this job much handy.
Posted on May 05, 2008
SOURCE:
Help! My Maytag MWA09149WH washer door wouldn't open!!
hi, the door locks when machine is in a cycle- wait till its over and door will unlock- try another cycle and see if it opens
Jul 20, 2015 | Maytag Washing Machines
My washing drained pump burned out. So i replaced it cleande the drum and refitted it all. The problem i have now is my waching machine turnes on and the pump runs as soon as the waching machine is turned...
If you can actually hear the pump running (as in not just hose too low and water draining out), I'd say that the main PCB is shot.
It was probably shot before you replaced the pump (pump burned out from constant running).
These models don't have an overflow as far as I know, unless it is pressure switch based (a possible issue if you did something odd cleaning the drum) remove and reseat pressure switch hose just to be sure.
May 27, 2014 | Washing Machines
Door wont open after cycle has finished, have put on a different cycle didnt work either, pluged out maching for 30 min didnt work either, can you help
Hi.
The door does not open because there is water detected inside the machine. Water must be removed through the drain filter connected to drain pump.
Disconnect power.
If front loader remove the trim panel at the base of the machine. Top loader have access at the bottom or at the back.
Locate the drain filter access at one side.
Remove drain filter cap.
Collect water using containers (have them ready, a lot of water will flow out).
Put back cap and trim and reapply power.
Emptying water from drain lines is usually enough to unlock the door. If that does not work, then the door is opened reaching back side of the door latch (from inside the washer's cabinet). Access is from top, after removing panel, or from bottom. Some front loader has an emergency unlock cord inside that can be reached undoing completely the drain filter. The procedure requires disassembling and should be done by a technician.
You can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Washing Machines
BensonbbbbMy door won't unlock. I have to hit the cancel button to open the door.
Hi... do you still have water in side the tub?? if so you have something in your pump or you need a new pump ... when the pump drains the door will unlock 9 times out of 10
Apr 07, 2011 | Frigidaire Affinity ATF7000E Front Load...
When the washing has done with the fanal spin the machine does not go to door open and we cannot open the door
hi the door lock will open providing the water is below a max level. Drum temp is lower than 40 degrees. drum has to stationery. blockages in the draining can cause some water retention to stop unlocking of the door also can retain hot water from the wash with possibility of higher than 40c temp at the end. you should here 2 clicks at the end to unlock the door if the machine is switched off it will unlock after 4 min by a failsafe device. Occaisionally i have known the machine to have hot and cold water pipes reversed causing all the rinses to be in hot water this would also stop the door opening. finally the door lock can be faulty or wiring to itand rarer the electronic itself.hope this helps
Nov 20, 2010 | Zanussi FJS1225W Front Load Washer
Is'nt the door interlock of the waching mahcine actuated by electrical solenoid mechanism when it is in running cyckle. If so . why cant we open the machine machine door by unplugging the unit to...
It's both electrical and mechanical. There's a water level sensor which is mechanically coupled to the switch, so even if the machine is unplugged it won't open until it's drained (open the debris trap if there is one or disconnect the hose from the pump inlet)..
Note that the switch itself remains energised electrically for a minute or two after the power is disconnected, the power comes from a large capacitor which slowly discharges.
Sep 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Siemens waching machine is on child lock how do I unlock it?
Select the mode in which the machine was running. And then press timer (Clock symbol) for 5 or more 10 sec. The lock will be removed
Jul 05, 2010 | Siemens WFXD8400UC Front Load Washer
My Haier waching machine has a slow spin cycle
I have the same problem with the same washer
Jan 26, 2010 | Haier Washing Machines
Whirlpool AWZ410 Front Load Washer/Dryer Logo
85 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
