Question about Sewing Machines
Chainsaw 141 oiler not working
I borrowed a friend's saw and the automatic oiler appears not to be working. What do I have to do to see what the problem might be.
email -
rkalina@cbe.ab.ca
  • Sewing Machines Master
  • 1,388 Answers
Somehow you have ended up posting this question in the Sewing machine section, so I suggest you re-post under chainsaws or you will never get a response......I don't know about chainsaws myself I am afraid, but if you have a sewing issue, let me know !
www.bargainbox.com.au
Posted on Mar 30, 2008
I've borrowed a memorycraft 300e from a friend. I've used it without incident for a few days but suddenly without any issues now whenever I turn the machine on I get an error message
Did you check the needle down button. Be honest and return it. Price one and wonder why you borrowed something so expensive. She may know what to do. But dont tinker or try to fix it. It seems like a fixable error. You probably afraid to tell her. But you stressing yourself out. If you borrow it you probably know a cheap embroidery machine is about $500. Just get it back and maybe she won't snap its probably something simple.
Nov 03, 2014 | Sewing Machines
Overload reset button on porter cable 10 in table saw
Why this is in sewing machines I will never know.
But this is an example of pushing a saw beyond it's limits. At best you should have cut one post, shut the machine off and let it cool... then go for the next. (Better yet get a friend with a saw mill saw the thing down for you)
I believe you have burned out your motor. Off the store you go....for a new one.
Oct 25, 2013 | Sewing Machines
Won't sew! Loads of top thread bundles up around bobbin casing.
First... make sure you are threading it correctly. It MUST be threaded with the foot up.
Do a test seam. Make sure you put the presser foot DOWN when you sew.
Make sure you grasp and hold the bobbin and top threads as you begin the seam. (this is good practice for any seamstress on any machine.
If you still get loops, tighten top tension.
Also check the bobbin case for burrs. drag a finger nail along edges to feel for it catching. If you find one take a small bit of extra fine sand paper and file it off.
Good luck
Nov 12, 2012 | Sewing Machines
I have a Singer Prelude sewing machine borrowed from a friend and the hand wheel won't go forwards manually.
there might be something stuck in between, just put few drops of oil in between the joint, and try it.,. it will work.....
thanks for rating Good luck
Jan 25, 2011 | Singer Sewing Machines
Hi,, my husque 141 dont seam to reach top end speed? it was ok till I cleans air filter
I am afraid you have confused sewing machines with chain saws!
One stitches fabric and the other makes a lot of noise and heaps of saw dust and wood chips.
Search the topics where the big boys play!
Mar 10, 2010 | Husqvarna Designer I
Chain saw probles
chain oil tank is pressurised...release pressure before storing...but it will still drip some
Mar 09, 2010 | Husqvarna Designer I
I borrowed a friend's serger (Europro 534 DX)for a
Try setting the differential feed to it's lowest setting.
Test with scraps of what you will actually be stitching.
Mar 01, 2010 | Euro-Pro 534DX Mechanical Sewing Machine
The machine got dropped and now it sews way too fat or dead slow sometimes not at all? it is computerized
It could be the foot control, see if you can borrow one from a friend to try. If this does not work then one of the circuit boards inside the machine has been damaged, the thing that controls this is called a potentiometer and where it is on the board may have cracked.
Circuit boards are often expensive to repair or replace, so try the foot control and if possible borrow a lead set as well.
Jul 01, 2009 | Brother CS6000i Computerized Sewing...
Chainsaw
I would suggest replacing your spring.
Jan 04, 2008 | Sewing Machines
HUSQVARNA 41 CHAINSAW CANT GET TO START
ok, remove spark plug and touch the threads (CAREFUL) to metal engine casting near plug hole. now try a start and look for a spark at plug.
Oct 04, 2007 | Sewing Machines
Sewing Machines Logo
105 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
