Question about Mitsubishi WS-65819 TV
3 colors on TV
I've had my 65" TV for apx. 6yrs. I currently have 3 colors showing and a arch like effect at the bottom and top of screen. I've been doing some research on the possible fix. It appears to be the convergence amplifier or IC pins needing to be resoldered. If this is true where are these 2 items located?
  • nineteenth May 21, 2008
    Display is multi-clored and unfocused at perimeter of the screen. After the set warms up the picture is beautiful as always. Returns to problem when turned of and powered up.
It sounds like we had the same problem. Our TV is the same make and model also about 6 yrs. I went to the Mitsubishi website and was able to find a service company in my area. It turned out to be the convergence amplifier. In the end we replaced a pair of convergence amplifiers and he also soldered the pins. (in home) The cost of the repair was $375, much less than purchasing a new TV. I realize I was no help in locating the amplifiers for you but maybe if you call a service company in your area they can help you with their location inside. Hope I was of some help.
Posted on May 16, 2008
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
The top and bottom of the picture makes a rainbow effect toward each other in the center of the screen++++++++TV. model 3 ws55807 it's a 55 inch screen the problem occurs all the time. I have no TV repair...
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than this tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.Fix the tv convergence board to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Mitsubishi WS-65807 65" Rear Projection...
When the display is dark i get red and green arcs on the screen
Color arching is an easy fix. You need a screw driver and some patience removing the front panel. You will be looking for a box with 3 screws on it. This is the color gun. THe scews are Red, Green and Blue color only, however, they usually don't indicate the color on them. Turn the screw (Slighlty) till the arching is no longer there. You have to do this with the tv on.. LOL
Best Regards and Semper Fi....
Aug 06, 2010 | Sony KP-65WS500 65" Rear Projection...
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
Arch in color on Panasonic
hello sound like convergance chips also check resistors and capacitors hope you get it fixed
shaun
Jul 31, 2009 | Panasonic PT-47WX53 47" Rear Projection...
The 3 colors are off, i have shadows and arches in the screen
It is failure of convergence ICs and these two ICs will be replaced on D board.
If you are comfortable with TV repair and know good soldering skills then can do the job easily.
Convergence ICs are mounted with sliver heat-sink on D Board of TV and part number will start with letter STK...
Get back to me if you need further info.
Jan 17, 2009 | Sony KP-57WS500 57" Rear Projection...
Can't set red convergence on 65" Hitachi
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 24, 2008 | Hitachi Director's Series 65XWX20B 65"...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Mitsubishi WS-65819 TV Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
