Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
Samsung HD tv help
I bought an HD samsung tv a little over a year ago, and recently, pretty much every time i turn it on, the pixels seem scattered all over the tv, moving around, i dont get what the problem it, its not the cable, because the pixels remain with or without cable, and they stay on when im playing my ps3, when i turn it on and off numerous times, sometimes it goes back to normal, but now its gotten really bad, can anyone help me out?
nilesh panchal
    Problem Solver:
  • 6 Answers
Is it a Plasma Television? I recently had a customer have the same issue with a 2 year old model Samsung 50" plasma TV. In his case one Of the computer panels failed. He didn't have a service plan and the warrenty was out, so i directed him to Samsungs help line. They inturn directed him to a authorized repair center. Repairs were roughly $800. Thats a possibility but it may not be the same as your issue. Try leaving your TV running for a little while when it has the issue, and see if it eventually goes away. Some older plasma models have started to require a warm up time for the pixel cells. This has been a down fall of plasma that for the most part no longer exists on newer models.
I hope eveything works out.
Have a great day
Posted on Aug 11, 2008
6ya staff
SOURCE:
Samsung 40" flat screen looses sound
this problem started on my LN-S4051D a couple of years ago. eventually the sound stopped working altogether. I then started using my surround sound speakers for the TV via optical out but soon that stopped working as well. I recently took the TV to a repair shop who said that the main board is bad and needs to be replaced. Labor plus parts was going to cost me $400. I said no thanks and paid for the estimate. Good luck.
Jun 27, 2010 | Samsung LN-S4051D 40 in. LCD Television
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
My 32 inch samsung lcd tv has got faint black lines running down the screen ,its nearly 4 years old but i expected it to last longer than that,and ive had sky hd box recently would that have anything todo...
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Nov 18, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung hdtv, purple pixels and trouble turning on
probably the power supply is going out.common problem.
Oct 27, 2009 | Televison & Video
Turn on tv and purple pixels like snow are spread around tv
Write down your serial # (found on the back or on the side) and your model # and call 800-Samsung. The issue has to do with the capacitors and if your TV was manufactured between Dec 2007 and May 2008 they will send a repairman out to repair for free (one time only). I just called and they are sending someone out to repair mine. Apparently there are tons of people experience the same problem.
Sep 12, 2009 | Samsung LNT5265FX 52 in. LCD Television
Samsung DLP white spots
Are the spots fixed or do they move with the image? Verify that all venting is clean of dust. If the spots are fixed and upon close examination are a square shape, The device is overheating of failing. If the spots are moving with image it's a front end problem, and can be overheating as well.
Jun 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Video problems with my westinghouse LTV 32 W 3 HD
This seems to be associated with the overheating of some component. On my set I need to check that the backlight is set to a low level. On reset it automatically adjusts to a level above maximum and the green screen will appear in a few minutes. I took the back off and that helped some.
Nov 27, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
No picture
When our tv does this,it seems like it's warming up. Sometimes it will eventually come on. Sometimes not. We discovered by accident that turning the floor fan on it (towards the back) helps.I didn't think it was that dusty back there, yet it seems to make a difference.
Sep 09, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
185 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
