Question about Canon imagePROGRAF W7200 InkJet Printer
Canon w7200 E02520 , empty ink tubes
Hello, the ink tubes become empty after some bad prints. i check all the tubes and the 6 valve are clean and good working, so i vacum and check the valves. now i take the ERROR E02520.
how can i FILL the tubes. how they can be fill with a programm? is there a pump under the valves, i don't see electric component in the tank... the open /close lever for the valves works ok. HELP !
SOURCE: Check Ink U130 5BK
Hold down the Stop/Reset button for 5 seconds or so - should start working now - although this stops the low ink warnings from then on
Posted on Jan 21, 2008
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
SOURCE: Error messages: U150 + Ink tank errors have occured
An on-line problem solver answered this question for me as follows, and it worked beautifully. I had previously tried just removing the ink cartridges, and then re inserting them, but that did not work.
"This is a somewhat common problem with the metal contacts that connect to the ink cartridge. Sometimes it can be fixed by cleaning the contacts, but other times it requires getting a new ink holder from Canon customer service.
To clean the contacts, you'll need a Q-tip and some isopropyl alcohol (it's important that it is isopropyl and not another kind of alcohol). Pull out the ink cartridges and clean the contacts on each one with the Q-tip dipped in alcohol. In particular, you want to make sure there are no fingerprints on the contacts. Then, turn off your printer and do the same with the contacts in the ink holder in the printer. Once the alcohol has dried on both sides, reinstall the cartridges and give it a try.
If this doesn't work, I recommend calling Canon tech support, so they can send you a replacement part."
According to Canon's instruction manual, you must complete the cleaning in less than 10 minutes. It took me about five. I did exactly the tech suggested, and after turning everything off and waiting a minute or so, I restarted everything, and the problem was solved.
You must be careful though, because if you leave a Canon Pi6600 cartridge out of the printer for more than 10 minutes, not only will the cartridge tray move back to the "off" position (out of reach), but the ink cartridges nossles will dry out and possibly not work. Also, do not "squeeze" the ink cartridges or you will get ink on yourself.
Posted on Jan 10, 2009
SOURCE: w7200 plotter - the ink tubes are empty
download driver printer canon mp 150
Posted on Jan 20, 2009
cene765
  • 787 Answers
SOURCE: canon mx318 u051
Try to press and hold the resume button for 5 seconds.If this not help you need to replace the ink cartridges.
Posted on Oct 26, 2009
Hi my plotter always print a blue color on all pages.for each kind i print i have it has no differences.does any one knows about my problem? my plotter model is Canon W7200 thanks best regards
Try printing the Nozzle Check pattern. Check if colors are printed correctly. If not, try Printhead Cleaning A first then check again the Nozzle Pattern. If there's a small changes to the pattern, try Printhead Cleaning B. If problem persist, try changing the Printhead.
Oct 09, 2014 | Canon imagePROGRAF W7200 InkJet Printer
Canon w7200
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 16, 2013 | Canon imagePROGRAF W7200 InkJet Printer
Print out blank page
Hello there.
What is the status of your ink cartridges? Are they empty? Has it been used recently or has it been turned off for long time?
All I can suspect from this little info you have given is the ink cartridges. Either they have become bad, or empty, which need to be replaced, or they didn't get inserted into the printer properly.
Thank you.
Let me know if you have any questions.
Aug 24, 2011 | Canon LASER SHOT LBP 3300 Printer
Installed new ink, cleaned & ran nozzle check, working good but computor still says low ink
When an ink tank becomes empty. ("No
ink error" displayed on the monitor, or
short flashing of an ink tank LED)
To replace the empty ink tank.
Oct 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
What does Waste ink near full mean
When the printer cleans the print heads it draws ink and disposes it to a foam collector in the base of the printer. Frequent cleaning via software causes this to to become saturated. To my knowledge it cannot be emptied or replaced easily and it is essentially the end of the printers life when full because the excess ink has nowhere to go and cakes on the print head. You can confirm with Canon or check the manual for replacement instructions.
Dec 08, 2008 | Canon Office Equipment & Supplies
ERROR MESSAGE FOR CANON BJ-W9000
Hi Caroline here is the problem defonition
E7260
: Nozzle check sensor unit error
E7270 to E727b/W7280/E7281/E7290/ E7291
:Nozzle check error
<Cause>
The position of the nozzle check sensor unit was faulty.
An abnormal condition occurred in the nozzle check sequence.
An abnormal vibration in the printer, the BJ print head is abnormal or no ink was
delivered to the BJ print head.
<Probable faulty component>
BJ print head, nozzle check sensor ***'y, linear scale, encoder sensor unit, carriage
controller, head controller, system controller.
<Action>
1. Check the ink filling status:
Execute "Fill Ink" from the Service Mode when there is no ink in the ink tube of
the carriage caterpillar component. Execute cleaning when the carriage air buffer
is filled but the ink tube of the BJ print head locking lever is empty.
2. BJ print head:
Replace the BJ print head if the above procedure does not solve the problem.
3. Nozzle check sensor check:
Re-install the nozzle check sensor holder unit if the installation condition is
incorrect.
If the installation condition is correct, select "Nozzle Check Position" from the
Service Mode, turn the power off and on, and obtain the updated and appropriate
nozzle check position.
4. Replace the nozzle check sensor ***'y.
5. Check the linear scale:
Visually check the linear scale for abnormal conditions, such as stains or damage.
6. Replace the carriage controller.
7. Replace the head controller.
8. Replace the system controller.
9. Replace the carriage unit.
I hope this helps
If not please get back to me
Thank You
Jun 13, 2008 | Canon BJ-W9000 Copier
Canon imagePROGRAF W7200 InkJet Printer Logo
385 people viewed this question
old marine
old marine
