Question about Philips 27PT5441 27" TV
Fuses keeps blowing them as soon as you turn it on.
    Scholar:
  • 135 Answers
Hi there!
Dead short in the power supply, possibly the rectifier or the PTC has failed. PTC located in the Primary supply at the point where the coil around the tube plugs into the Main board. Two terminals to be exact. Normally cream in colour if it is an original Philips PTC. If the rectifier is short you may expect to have more items blown. Good Luck, Regards, JUS004
Posted on Mar 24, 2008
What could be causing the front axillary fuse to keep blowing? Even bigger fuses blow.
fuses blow from over current( dead short) they are rated at lower than what is required so that the wire doesn't burn
If you keep putting in bigger fuses without fixing the dead short, eventually the wire will melt the plastic insulation off and the vehicle will burn
Apr 29, 2016 | 2005 Buick Rendezvous
Keeps blowing auto shut down fuse as soon as key is turned on
Could be several things including one of the oxygen sensors, one of the injectors, the coils, or the engine computer.
You will probably need to get a shop manual to get all of the wiring diagrams connected with that circuit. And I would suggest you use a circuit breaker to check each one instead of fuses.
You'll have to disconnect each component until you find the short.
Oct 18, 2015 | 2004 Chrysler Town and Country
Wind shield wiper blowing fuses
You have a short circuit to ground when the switch for the wipers is turned on. It does absolutely no good to keep replacing the fuse until the short circuit has been located and repaired. I guess you are just starting to figure this out five fuses later.
The lesson here is that fuses do not cause electrical circuit failures. Electrical circuit failures cause blown fuses. There are many people that do not understand this.
If the fuse remains intact until you turn the switch on, you will find the problem between the wiper (combination) switch and the wiper motor assembly or the wiper motor itself.
Nov 23, 2011 | 2004 Kia Sorento
THE MICROWAVE KEEPS BLOWING FUSES, AS SOON AS I HIT THE START BUTTON THE FUSE BLOWS.iT WILL KEEP THE TIME AND THE LIGHT WILL COME ON BUT AS SOON AS i HIT START IT BLOWS
Sorry to read about your problem, I hope this helps you out.
you have a defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Kenmore 63792 Microwave Oven
Subwoofer keeps blowing fuses.
THE AMPLIFIER "IC" MAY BE SHORTED!
IC MAY NEED REPLACED.
Apr 10, 2010 | KLH ASW10-120 Subwoofer
Husqvarna yth2348 keeps blowing fuses as soon as one is changed and you attempt to turn it over the fuse blows
You have a dead short in the circuit for that fuse. Check for a pinched wire, or a wire rubbed thru a touching metal.
Sep 28, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Toyota Camry 1994 Main Fuse keeps blowing
-if your fuses are blowing
-the problem is in the wiring
-because if too much amperage flows through the fuse will blow
-there's probably a short to ground somewhere or high resistance after the fuses causing it to draw more amps
Mar 19, 2009 | 1994 Toyota Camry
Help my fuse is blow!
If the amp blows fuses only AFTER you send remote turn-on voltage to the amp, the amp probably has blown output transistors. To eliminate other possible causes, read through the following page.
Amp Troubleshooting
Let me know if you have any other questions.
Aug 25, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Philips 27PT5441 27" TV Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
