Question about Philips 27PT5441 27" TV
Philips 27pt5441/37 Keeps blowing fuses as quick as i turn it on
  • kaito Mar 26, 2008
    Thanks for the help, I guess either way its not worth fixin.
    Scholar:
  • 135 Answers
Hi there!
Dead short either in the power supply or rectifier, or PTC faulty.
PTC is cream in colour close to the mains on/off switch. Regards, JUS004
Posted on Mar 25, 2008
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
Magnavox 37MF437B/37 keeps blowing fuses
Either a short somewhere---which fuse? The one at the power cord or what?
Other possible reason is wrong fuse----many of the fuses in these sets are special-----if you go and buy some Generic ones--hardware store or Radio Shack the fuse even with same amperage/voltage rating may blow at turn on instantly for no reason------
Dec 08, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Fuse keeps blowing on my Philips 32pw8608/12
Please, never try to replace a fuse, without checking for any short circuit inside. You will only increase the damage inside. It is advisable to call in a qualified service technician as opening back cover by unqualified personnel is hazardous.
Aug 15, 2012 | Philips Televison & Video
Fuel pump fuse keeps blowing on my 95 Crown Vic
Using a smaller fuse should make the problem happen more often.
A mechanic would unplug the pump harness at the tank and check the circuit for high resistance or a short to ground.
If nothing is found in the harness, I would suspect the pump in the tank.
Jul 19, 2012 | Ford Crown Victoria Cars & Trucks
No power or light, plus power supply keeps blowing fuse
you have a short most likely on the power supply but could be on the mainboard, inverter board, av/input board. The T-con board is fused and should blow its fuse before blowing the fuse on the power supply. I'm going with a faulty power supply, most likely a shorted Mosfet.
Sep 24, 2011 | Philips Magnavox 42MF521D/37 Television
My a/c keeps blowing a fuse everytime i try to turn it on, its the #10 fuse that has the 4wd and a/c on the same one
Unplug the connector at the A/C compressor, and then put a good fuse in. See if that blows the fuse. If not, your compressor and or clutch is suspect. If it blows again, something in the 4wd is suspect. I'll will bet that a quick call to your Ford dealer service manager will help. There are just too many things to try and pinpoint it in this forum, and without a scanner we would just be guessing. Sorry!
Aug 29, 2011 | 2006 Ford F-150
The fuse on my Yamaha YBR125 keeps blowing.
Did you replace the fuse with exactly the same fuse? There are slow AND quick blow fuses, BIG difference.
Apr 11, 2010 | 2007 Yamaha Ybr 125
Fuse keeps blowing in the subwoofer on my Philips hts-3450
Replace the capacitors with ones of the correct v. Download latest manual from Philips website to verify if the capacity value is not a typing error.
Jan 03, 2009 | Philips HTS3450 System
Keeps blowing fuses
When a fuse keeps blowing, that is an indication that some component has failed and the circuit is drawing too much current. Most likely it is a problem in the power supply section or high voltage / flyback section.
Sorry to say, you will need to take it to be serviced.
Please let me know if I can be of further assistance to you.
- Jim
Feb 09, 2008 | Philips Magnavox 20MC4304 20 in....
Philips 27PT5441 27" TV Logo
182 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
