Question about SanDisk Sansa Clip MP3 Player
Does not come on after charged
Wen i finish charging my mp3 when i go to push the power on, it never comes on, eventhough it is charged. what shall i do??
  • dkcaprice Mar 27, 2008
    all right i have the same problem can some please help me it is fully charged and comes n when plugged into the usb but when taken off the usb it wont respond at all and i have held the power and everything please help
  • mi mii Apr 01, 2008
    my mp3 playernever cmes on after i charge it
    Problem Solver:
  • 8 Answers
If the usb does not work it means that the usb you bought was a fake or something is wrong inside
Posted on Mar 26, 2008
My coby mp705 wont turn on but when i plug it to my computer it works.. what kind of assistance shall i do to make my coby back to normal? any kind of answer would be wonderful
sounds like the battery is the problem if it wont start wothout a power source
Check the system requirements for the MP3 player.
Most Coby players require Windows XP or higher and at least 1 GB of RAM to function correctly.
Check your Coby owner's manual to ensure that your machine meets all the required specifications before proceeding.
Charge the MP3 player fully.
Often, a player will act unexpectedly if it has a low charge.
A charge can also help reset the MP3 player if it has frozen or locked up.
Once the player has finished charging to 100%, see if the problem persists.
Re-sync your player.
Plug the MP3 player back in to the computer and then remove all the files.
If you have not done so already, make sure they are backed up to your hard drive.
Unplug your MP3 player and then re-load all of your files.
Check for corrupted and wrong format files.
Most Coby MP3 players only play back MP3 files, and will perform unexpected operations
if files of other formats are uploaded to the device.
Go through your uploaded files and check the extensions.
Anything that does not say ".mp3" or is not listed in your owner's manual needs to be deleted from the device.
hope this helps
Sep 30, 2012 | Coby MP-705 Digital Media Player
Wen i turn it on it says battery too low system shut down but wen i plug it in too charge it dosnt charge up it just says the same thing
Possible that the battery can be bad, so to confirm first check the charger adapter of the player and see if the voltage is good. If so let the player shuts down with the power fully OFF.
The set the charger ON for a full day and check the player to play. If the player fails then it is possible that the battery is faulty.
Try to open and check to confirm before you can replace.
Dec 30, 2010 | SanDisk Sansa e200 MP3 Player
My i pod is not getting charged eventhough it is connected to computer.
SOME LOW POWER USB PORTS MAY NOT PROVIDE ENOUGH POWER TO CHARGE THE PLAYER
The battery can also be charged using an AC adapter
Mar 04, 2010 | SanDisk Sansa e260 MP3 Player
YPK5 Stops
connect it to the computer and charge 4 round bout 30 min n take it out and hold on wen it comes up it should work again dats wat i did wen dat happened
Aug 31, 2008 | Samsung YP-K5 MP3 Player
IPOD SHUFFLE
It should come with a connector to plug into the ipod. When the other end of this connector is plugged into the power socket on the wall, it should start charging the ipod.
If the above still doesn't work, what happened when you said you couldn't get it to charge? Did the word "Charging" not appear on the screen, or the "Charging finished" words not appear after plugged in for a long time?
Jul 17, 2008 | Apple iPod MP3 Player
Broke
before i had the same problem, when i thought my k5 runs out of battery i plug it in to charge, but it said charge complete and when i unplug it, it still wont turn on. but then i tried switching to a different usb plug on my computer and it worked. so i guess the problem is that some of your usb slot on your computer isnt working properly, try using a different slot.
Jan 20, 2008 | Samsung YP-K5 MP3 Player
MP3 PLAYER
try resetting the player by pushing a paperclip in the reset hole at the back of the player.
Jan 14, 2008 | Samsung YP-K3 MP3 Player
Rca
Your circuit board was still moist or corroded when you charged it. This caused a short in your player. There is no telling what the future holds for it. Any electronic that gets wet must get disassembled and dried out otherwise it will corrode the connections.
Nov 07, 2007 | RCA OPAL M4001 MP3 Player
My lyra wont turn on
Take the battery out and then put it in again and it should work again
Aug 15, 2006 | RCA Lyra RD2820 20 GB MP3 Player
SanDisk Sansa Clip MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
