Question about Cameras
When I turn the camera on it says card locked.
  • 3,037 Answers
Take out your memory card and on the side of it is a small tab or button, move the button to the other position and this should unlock your camera. I hope this helps, thank you and good luck.
Posted on Mar 22, 2008
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    Have you tried to get it working yet, if for some reason this is not the problem, please let me know, I will be more than glad to help you out
    Genius:
  • 3,422 Answers
Here's the solution
1. take the memory card out
2.On the memory card there is a little switch (it will be the little tiny piece on the side of the card thats a different color) slide it up.
That's it!
Goodluck,
Please don't forget to rate the solution.
Have a pantax 7.1 camera need to turn off card lock
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 13, 2014 | Cameras
My screen has Card Lock on it when I turn the camera on
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 17, 2013 | Cameras
Get card locked message when I turn camera on. Can't turn the message off,\.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 14, 2012 | Samsung SL35 Digital Camera
I keep getting "card locked!"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps for this problem are listed here.
Aug 24, 2011 | Canon PowerShot SD960 IS Digital Camera
My Canon A460 says the Card is locked. The lock switch on the card is set to unlock. I have another camera with a similar card. Both cards work in the other camera. neither card will work in the A460 both...
back up your data first,thenyou reformat the memory card in the camera.i guess you have formatted the memory card in another device.canon cameras generally do not accept cards that have been formatted in another device.then sitch off the camera and reinsert the memory card.
Jun 27, 2010 | Canon PowerShot A75 Digital Camera
Card is locked
There is a small lock switch on the side of the memory card, slide it to the other position and try again.
1. Turn the camera off
2. take the memory card out
3. slide the lock slider to the other position
4. place the card back in to the camera
5. turn on the camera.
if the problem remains repeat steps 1 to 5.
if the problem still remains its now obvious the issue is not with the memory card, you may try another card on the camera if you wish.
The most likely cause for this issue is in the memory card reader of the camera. there is a small lever/switch on the side of the card reader that detects if the card is locked or unlocked. You would have to take the camera apart and pull the stuck lock "detector"/switch up so that it doesn't touch the the metal.
Sep 06, 2009 | Canon PowerShot SD850 IS / IXUS 950 IS...
Unlock card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 10, 2007 | Pentax Optio 550 Digital Camera
Card Locked
remove the memory card out of your camera and look to the side of it.. there is a little switch on the memory card that locks the card... try that first it might not be your camera... :) good luck :)
Nov 04, 2007 | HP Photosmart R707 Digital Camera
Cameras Logo
29 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
