Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer fills with water by itself
I have a Whirlpool Duet Washer Front Loader model GHW9150PWO, This washer fills with water by itself, and I don't know why it does this as it does not do it all the time. maybe 6 - 10 times a month. any ideas or things I can check.
  • 2 more comments
  • armor575 Apr 04, 2009
    water drips into washer when washer is idle for aperiode of time//front clothes washer duet/ GHW9150PWO
  • Anonymous Apr 06, 2009
    water drips into washer when not in use. also at end of cycle, so clothes are drenched if not taken out right away. about how much is the repair for a new valve?
  • Anonymous Mar 27, 2014
    Washer fills when door is open between use
  • Anonymous Mar 30, 2014
    press start and water begins to fill. Does not go into tank and overfills onto floor
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Posted on Mar 23, 2008
Duet whirpool front loader is filling with water on its own
The washer fill valve is defective and will need to be replaced. The fill valve is right under the main top at the back the fill hoses attach to the valve.
Oct 07, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9150pwo code f h
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all
the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the
inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to
Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain
Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
Don't get too deep into the washer itself and void your warranty!
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Gentle cycle did not complete leaving water standing in the tub.
Whirlpool downloader washer model number GHW9150PWO
PROBLEM Gentle cycle did not complete leaving water standing in the tub
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet f/l loader. The washer fills with water when not on
I FOUND THE PROBLEM WAS THE VALVEWHICH CONTROLS THE WATER INTAKE ON THE TOP OF THE WASHER. I PICKED UP THE REPLACE VALVE IT WAS LOCATED AT THE TOP OF THE WASHER WHERE THE WATER INTAKES ARE. THIS SOLVED MY PROBLEM.
yOUR SITE WAS VERY HELPFULL
THANKS ****
Nov 26, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool duet front loader washer-leaks into washer when not in use
Yes, but if something gets into the valve it may prevent it from sealing correctly. Unfortunately these valves are all molded plastic around the seal, so there is no way to repair it. You'll have to replace the fill valve.
Jul 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer should fill, remove hoses, check screens in hoses and or valves on machine for clogs. Verify water valves at the source are turned on. If all this checks, you need new valve installed on your washer.
May 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
600 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
