Question about Sungale DVD-2026 DVD Player
Wrong disc message displayed on screen for dvd-2026
  • 1 more comment
  • j_iftikhar Mar 28, 2008
    DVD will play in all other players but this one. Always gives me Wrong Disc message..
  • cjgcad Jan 25, 2009
    This dvd player will not play a movie that works in another dvd player. It reads wrong disk.
  • will-fix-it Mar 19, 2009
    My Sungale also sz "wrong disc" every time. I tried the solutions above, to no avail. Any other suggestions? I do know the DVD's work.
I found these posts. I have only been able to get the fix to work once, though. :(
I found a "hack' to make mine work :)
1. Open the tray
2. Press "Setup": Menu Screen should appear
3. Press "8-8-8-8" ( if you changed the password, you might have to change it back to 8888 ) The region number should appear on upper right corner. No other notation. Typically just the numeral "1".
4. Use the right (->) or left (<-) arrow keys to change the region to 255 for all regions.
5. Use the up or down button to go to 3001 and 4000. I had to change 4000 to 4001 to get mine to work,
6. Press "Setup" to exit.
It was a big relief to find this hack, because I misplaced my receipt and thought I was simply out of $30.
Region code hack posted by jeff777, December 15 2004:
This works.
1) With remote control, power the DVD player on.
2) With remote control, open the DVD tray.
3) With remote control, select SETUP.
4) With remote control, press the VOLUME UP button, then the VOLUME DOWN button, then the VOLUME UP button again and finally the VOLUME DOWN button again.
5) You should now see a number 2 on your screen. If you do not, this hack will not work on your system or you have done something wrong. If you do see the number 2 on the screen, proceed to 6).
6) Use the LEFT and/or RIGHT arrow to select the number 255.
7) When you see the number 255, press the SELECT button.
8) Press the SETUP button again to end procedure.
Region code hack posted by RayH, May 18 2005:
Newer Sungale 2026 players are a bit easier to set up:
1. Open the tray
3. Press "8-8-8-8" Region number should appear on upper right corner. No other notation. Typically just the numeral "1".
4. Use the right (->) or left (<-) arrow keys to change the region. "255" all region.
5. Press "Setup" to exit.
Tested Region 1, 2, 3, 4, and 5 PAL and NTSC disks. They all work just fine on an older US NTSC TV. It's a little bigger than the Cyberhome, but works much better. There is no jerking at chapters with either factory or homemade discs. Plays VCDs just fine.
Sniff around the internet. This machine is availabe as of 5-18-05 for about $29 plus shipping ($11). Arrived in two days.
Other hack posted by Hurricane, January 23 2006:
If you do the Setup>8888 thing you get a region code 1-6 & 255.
Well if you press up and down on the directional pad you also get 3001 and 4001 these can be changed to 3000 and 4000, I know that one of them is a Macrovision on/off flag but I don't know what the other is.
Region code hack posted by Streetmedik, March 25 2006:
I have the Sungale DVD2026 I have tested this with DVDs from various regions. It works.
1. Power on
2. open the tray.
3. ON THE REMOTE press the VOLUME up, down, up, down.
4. ON THE REMOTE press SETUP
5. ON THE REMOTE press the up and down arrows to go between the macrovision/region codes.
6. ON THE REMOTE press the left and right arroes to change the values.
Macrovision
3001 on
3000 off
Regions
1,2,3,4,5,6 = individual regions
255 = all regions
7. ON THE REMOTE press setup again and you are set.
You can change these values again and again If you just want to play around.
Posted on Jul 26, 2008
  • haiau21_dat Nov 23, 2010
    I did all of the following steps except that I have to press setup twice at the end for it to exit setup. The first one only makes the 3000 or 4000 number disappear. The second setup gets it out of setup mode.
    Using the remote: power on
    1. Open the tray
    5. Use the right (->) or left (<-) arrow keys to change from 4001 to 4000 and 3001 to 3000
    5. Press "Setup" the number 3000 disappears
    6 Press "setup"again out of "setup" mode
    7. put in a disk and close the tray.
    It still displays "Wrong Disk" I did go back to check and the numbers 255, 3000, 4000 were there.
    My DVD2026 is brand new from a couple of years ago. Please helps
Wrong disc
Hello
Try an other disc. Soem discs may not recogonized. It will depend on its recording. Put an MP3 and Audio CD disc in it and see whether they are regognaized by the player. If it does not reads any disc, there are two possiblilities for this fault. The first one is of dirty or dusty laser pickup lens, and the other is with a faulty laser pick up uit itself.
Just put a cleaning disc in it, and play it for at least three times. Check it after. If this does not hel you, beofre replacing the laser pickup unit, just replace the strip wire that goes from this laser pickup unit to the main board. It is a flat thin cable, can be bought from most of the electronic spare part selling shops at your town.
Even repacing the strip wire, and cleaning does not help you, you have to repalce the laser pickup unit. OK.
Dec 17, 2011 | Sungale DVD-2026 DVD Player
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
It keeps diplaying wrong or no disc
the problem is not recognising the cd / dvd, you can clean the lense by puting a lense cleaner cd, it is aviloble in the market.
Apr 11, 2011 | Sungale DVD-2026 DVD Player
Wrong disc
this problem is normally a fault due to using a dvd disc that is not from your country region. check the dvd box and make sure the region code matches your country that you a veiwing it in.
Jul 12, 2010 | Sungale DVD-2026 DVD Player
My dvd player displays 'wrong disc' and will not play. what's wrong?
The reader in the player might be dying. Try another disc. If that works, the disc is in a format the dvd player cannot read (i.e. BluRay, DVD+R, etc.)
Dec 29, 2009 | Sungale DVD-2026 DVD Player
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
Dvd player
it might not be a dvd disk
Mar 28, 2008 | Sungale DVD-2026 DVD Player
DVD player will not play
my brother the only way you can override that lock is that the microchip in the set has to be lift out of the set,by doing that the chip will reset itself then the chip can be resolder back contact a tech to do it for you.goodluck.
Mar 29, 2007 | Sungale DVD-2026 DVD Player
Hangs/ "wrong disc display"
yea take your DVD player to a repairman your micro could be your problem.good luck.
Apr 06, 2007 | Coby TFDVD7050 Portable DVD Player with...
Sungale DVD-2026 DVD Player Logo
439 people viewed this question
Top Sungale Televison & Video Experts
Henry  Thomas
Henry Thomas
janman
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
