Question about Toshiba TLP S30 Multimedia Projector
Hey Guys I have the TLP-S30 and the (compact disc) owners manuel that came with the projector cracked do you know where I can get another one. Thanks Auset
  • 563 Answers
Auset
You can go to www.projectorcentral.com and go to Projector brands.
Simply click on on your brand and model and download the Users Manual and burn to CD if you wish.
Posted on Mar 26, 2008
Small glass slide between light source and lcd cracked and black
That could be a polarising filter.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP s30 projector identification part
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP-S30 loses calibration/alignment with whiteboard.
there are phisical adjustments for the projector itself. is it on a smartboard? hold down the 2 buttons on the pen tray until the 9 point callibration screen appears. the points react to stylus release, so put the stylus near the point and "draw" a line to the center of the point then release. do the same for the other 8. that should do it.
Dec 11, 2009 | Toshiba TLP S30 Multimedia Projector
Internal fan location in TLP S30, I get an error message about internal fan problem
one of the fans arent working. there should be at least 3- one for the lamp, one for the power supply, and at least one for the lcd panels. you should be able to see the one for the lamp and power supply from the outside. if both are spinning, it's the other one, which you might be able to see from the bottom.
Sep 22, 2009 | Toshiba TLP S30 Multimedia Projector
No signal projector (TLP-S71)message connect to laptop
make sure the cable is good. then make sure the resolution matches.
Jul 28, 2009 | Toshiba TLP S30 Multimedia Projector
White areas in the image are yellow and the black are blue-green
you have a few issues. first is the yellow in white. the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you may have to replace the whole optical engine. as for the flashing horizontal lines, the power supply isn't cooling down and the caps are drying out, causing fluctuations in voltage. so, replace the power supply.
Jul 04, 2009 | Toshiba TLP S30 Multimedia Projector
Unsupported Signal
Hi Circuitrider
Just change the resolution on your PC to match that of the Projector i.e. XGA Projector = 1024x768 resoltuion.
If the problem still persists , the Mainboard is at fault and will need either replacement or repair.
May 13, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP-S30
Make sure the lamp cover is in place as it has a plunger on it which closes a switch . If the switch is open you will never power on. With the cover remover you can manually actuate the switch too and it will power up.
Oct 16, 2007 | Toshiba TLP 261 Multimedia Projector
Toshiba TLP S30 Multimedia Projector Logo
90 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
