My computer stopped working all together and just to be able to access the net to contact support i have borrowed a disk from a freind to temp install vista again i never got any disks at all and the computer would not allow a back up to be made please help
  • 778 Answers
If you didn't get a disk then there should be a partition on your C drive containing the restoration to original configuration data. Consult your manual on how to restore your system from that partition (probably have to tap a key like the "C" key on boot to access the restoration partition). As far as I know no current computers come with OS disks.
Good luck
Posted on Mar 22, 2008
Operating system running slow Compaq nx7400 PC Notebook
One of the common problems but can fix it.
Clear the temp files first.
1.Goto Run prompt ( press windows logo button and R button together)
type %temp% and hit enter
delete all files
Goto Run and type temp and hit enter and delete all files
Goto Run and type prefetch and hit enter and delete all files
Open My computer and right click on C drive and select properties
click Disk clean up and check all the boxes and clear it and restart your computer
YOu can also increase the virtual memory and it is recommended to have 1.5 times higher than the memory installed on the computer
Also uninstall any unwanted programs from add or remove programs and restart your computer
These are the basic steps and you should see significant improvement.
I had the same issue and I had contacted online technical support and got in touch with TheBestPcDoctor. They are the best in this issue and tuned up my computer and now it is working 3 times more faster than it was before. I also would suggest you to contact them and see for yourself. You may contact them @ or via 877-407-9229
Oct 04, 2011 | HP Compaq nx7400 Notebook
The boot manager has been wiped from my motherboard
Try to check your disk here is a link to explain using your installation windows disk
If you don't have a disk you can probably find one on the net or borrow one..
Start your computer press F11 start from the cdrom with disk in and press r for repair when prompt
You can also take the hard drive out and connect it to another computer as a second drive and run that computers command prompt.. Type CHKDSK (Your Drive: ) /F /R... on ..Example mine says CHKDSK D: /F /R press enter type Y for yes and enter don't turn off the computer.. when it is finished type EXIT and put HDD back in the another computer and start it
May 16, 2011 | Computers & Internet
If you don't have a disk you can probably find one one the net or borrow one..
May 13, 2011 | Visual Land VNet VL760 Netbook
well im sure since your on the net now your computer doesnt have a connection problem i would try downloading new java and other related updates i would also recheck your system requirements because sometimes if your requirements and the lowest needed its too much for the computer to play with other players on the net (overloading) and is none of the above check your core temp (cpu fan) in your bios .. google it .. and google normal temps to see if your temp it healthy(considered bigger fans)... remove old files that can slow down the computer and go to start>allprograms>acessories>disk clean up let it run and then disk defragment... you should see a slight change in your computer performance.. and if all else fails call your internet provider to help establish connection issues
Dec 09, 2010 | New Media Lego: Universe for Windows
I have a Maxtor Personal Storage 3100 80 GB Hard Drive which has always worked and listed as drive G. However, on eday it just stopped listing drive G. Everytime I connect it to my port hub or to the...
Try a different "data" cable between your computer and the external disk-drive.
If there is an external power-supply, borrow a "multimeter", and test that the power-supply is supplying power (correct voltage and correct amperage).
Try connecting it to another computer.
Disassemble it, and disconnect the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if the disk is working.
If it still is under warranty, either your local retail store, or Maxtor/Seagate will honour the warranty, and replace it.
Jun 15, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
Cannot download audio driver which I already used the tag . I have problem with download
2 real things to here my freind you could download using a freinds computer and burn to disk and use on your's or you could get a sound card there only 2 to 3 pounds from maplands hope this helps
Jun 02, 2010 | Dell Precision 360 Workstation/Personal...
Black screen + mouse cursor, no access to explorer.
Windows needs to be reinstalled or repaired. Obtain a XP or Vista repair or installation disk (possibly borrow from a friend?) and run a repair installation. If you have another computer running windows you can make an installation disk from that computer.
Apr 15, 2009 | Dell Precision 410 PC Desktop
No connection to internet
First thing you need is to run the set up disk that you should have received when you purchased modem. It should run you through the steps. This should also allow you to set up your wireless connection also. It should also provide you the access code for your wireless security. Basically what this does is prevent unauthorized access to your network. Whenever you add additional computers you will need to set up each individually and enter access codes. If you don't have a disk you might need to contact manufacturer to get a replacement disk. Good luck.
Oct 18, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Boot problem - Win98SE
change the boot sequence in bios set up ...
keep in this order
first boot device as floppy
2.hard disk
then save it and then have a check it should work ..
you have not mention hard disk here so i think the hard disk is not detected there may be some loose contact inside and it is not connected properly so it is not able to verify DMI pool ...
if so connect the hard disk properly then then have a check it will surely work..........
Feb 23, 2008 | Microsoft Windows 98 for PC
Open Questions:
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
