Question about Car Audio & Video
Help my subs only work with my radio and not with my cd
I just had the same thing happen to my friend's car. More than likely your remote wire from the amp is connected to the remote wire for your power antenna comming from your deck. There are usually two blue wires coming from the back of your deck. Simply take the remote wire from your amp and connect it to the other blue wire coming from your deck and you should be good to go.
Posted on Feb 06, 2009
Make sure you used the blue with white stripe wire from your head unit for the remote wire for your amp. The solid blue wire is for triggering on the power antenna and does not supply voltage in CD or AUX
Posted on Aug 21, 2008
SOURCE:
SUBS NOT WORKING WITH THE CD OR aUX
Since the subs work with the radio, then there is nothing wrong with the speakers themselves. The issue must lie with your radio or control unit.
Jan 20, 2014 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have an amp powering two subs but only work with the radio and not when its in aux mode or cd mode. do i need some other conection
I am not familiar with your head unit but I know some radios can control audio options for each source. My unit has adjustments for bass treble fade sub out etc in each source like radio, dvd, cd usb etc. I would check this first. For example, my radio can have the bass set to zero while the dvd can have the bass set to 5. If this is the case for your stereo, the sub out for the different sources can still be set to off.
Feb 22, 2010 | Alpine CDA-9851 CD Player
No sound
hi there
on your CD deck or what ever unit you plugged the RCA wires to needs to be set on subs the radio needs to be set to put sound to your amp.....on your CD player if you press the F/function button a few times it will scroll to SW which is for the subs set this to the on position or if your CD player has a button with SW press it and turn on this feature......if this has been done......check the fuse or fuses on the amp.......if you have done all of the above check the back of the CD unit to make sure you are plugged into sub-woofer RCA or R (rear) RCA ..........sometimes people accidentally put the RCA wires into the aux input RCA,,,,,, double check this.........
hope this helps
Mar 07, 2009 | Crunch PZi1000.1 Car Audio Amplifier
Troubleshooting in car cd player
that is very strange but it could be that when you put the cd in the radio it maybe sending out a quick shot of amplified power I would try disconecting the subs put in a cd let it play a little then plug the subs in while the cd is playing and see if they work if this works you may to get a new radio or put in a switch to turn the subs off or some type of momentary circuit breaker I'm just trying to help I never saw anything like that before good luck........
Nov 06, 2008 | Sony Xplod CD Player w/MP3 Playback...
My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Jun 24, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Subwoofers not working While listening to CD
The remote turn on lead for the subwoofer amplifier has been connected to the power antenna lead (solid blue) of the radio. It just needs to be connected to the radios amplifier turn on lead (blue with white stripe).
Jun 14, 2008 | Kenwood DNX7100 Car Video Player
Amp and subs cut out when I insert a cd in my radio
You have the amp connected to the blue wire on the radio instead of the blue one with the white stripe. The blue one is the power antenna wire so when you switch to cd, it would close a power antenna. If you dont have a blue /white wire, you can hook it to the red 12v wire. Good Luck
Mar 07, 2008 | Car Audio & Video
Radio works cd/dvd does not.
What do you have your remote wire for your amplifier connected to?
Dec 05, 2007 | Panasonic CQ-VD7001U Car DVD Player
Car Audio & Video Logo
193 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
