First take the USB cable out of your computer, then put it off and then on again...it starts to print the test page again...then after the printer stops printing, put the just printed testpage face down on the scanner(glas) and press scan manually...after the scanning(you wait till that is finnished) and then put the printer off and on again....then connect the USB cable to the computer and that will stop the printer from printing the testpage every time you startup your printer....
SOURCE: Printing of Test page when you turn on the printer
check the print queue from the computer (printers and faxes, right click printer icon, cancel all documents)
SOURCE: Only prnting the startup page every time I send a document to print
This is likely a problem with the printer driver or the printer spooling system on your computer. Check in folder "C:\Windows\System32\spool\PRINTERS". If there are files in this folder at any time when you are not expecting a printout and there were no system messages, then it is confirmed.
The easiest thing to try is to uninstall and reinstall your printer drivers. If that does not do the trick and a problem with the printer spooling system, you might be able to try uninstalling and reinstalling this feature. If this does not work or you cannot do figure out how to do it yourself, you will need a Windows expert to fix it for you.
SOURCE: Always Prints a test page at startup
unplug all the cables connected to the printer including the power cable,,
but do not power off the printer,,
remove the power cable when the printer is on,,
then tap the power button for 20 - 30 times,,
then press and hold the printer's power button for 30 seconds,,
now plug back the power cable,,
once that is done then go and allign the printer once again,,
this can be done from the menu of the printer,,
press the menu button then go to tools and then press on allign printer,,
that ill work for sure...................
