Question about Frigidaire FDE336RE Dryer
Dryer heating dryer heats sometimes and sometimes it wont.....any advice? I, too have a Frigidare Dryer (Model # fde216res2) that does not heat up. I discovered a thermal limiter on the inside back wall of the cabinet that does not have any wiring connected to it. I replaced the heating element with a serviceable one and rewired from a three prong to a four prong power cable. Internally, from the cable wiring box, I found the wire leading to the red wire connection was cut. I'm assuming this led to the thermal limiter. However I don't know where the lead to the other pole on the limiter is supposed to go.I looked for a wiring diagram on the Sears on-line Parts catalog and did not find a suitable diagram for determining the correct wiring for the thermal limiter. Can you help? PS: I have ohm checked the thermal limiter found it to be okay. Thanks. Dave W. daybug8@satx.rr.com
  • 3,037 Answers
Http://www.applianceaid.com/newimages/GLER331A.jpg
http://www.applianceaid.com/images/swfedwd.jpg
These links will help you out, both are wiring diagrams. I hope this helps you out and solves your problem. Good luck and don't forget to rate this solution.
Feel free to post more on this issue if you need to
Posted on Mar 22, 2008
  • Benjamin Patri
    Benjamin Patri Mar 22, 2008
    http://www.applianceaid.com/diagrams.htm...
    this is where I got the two picture diagrams from if it helps you
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    Have you tried to get it working? Any other questions you have or anything else? We're here to help.
    Genius:
  • 1,665 Answers
My whirpool gas dryer model number wdg6200swq, wont heat up. the ignitor lights but no gas lights
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 02, 2011 | Whirlpool Dryers
I have a Kenmore Elite HE4 dryer model 110.95876400. Its running but no heat is coming out and clothes wont dry.
heatman101
Feb 17, 2011 | Dryers
Dryer heats sometime other time wont heat
heatman101
Sep 26, 2010 | Maytag Dryers
Kenmore gas dryer model number 111.76712693 no heat coil wont light up do you think its the igniter sabrefan29@yahoo.com
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 23, 2010 | Kenmore Dryers
Model #w8w2780wcwww over and under. dryer works but does not heat. ge model
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | GE Dryers
Frigidare gallery not heating. possibly heating element is gone out how hard is it to replace
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Jul 01, 2010 | Frigidaire FER231A Electric Dryer
My Frigidaire model GLEQ2152ES0 will run but the air does not get hot.
Need to order the resistant heater, use the mothel of the unit to make the orther
Aug 11, 2009 | Frigidaire Electric Dryer
Frigidare Gas Dryer - get some heat, but NOT hot enough!!
You say its a gas dryer...there is no element. Have you cleaned the lint trap. Is the vent clear of obstructions? I suspect one of these issues will be the problem
Mar 16, 2009 | Frigidaire FGQ1442ES Gas Dryer
Ge dryer not heating
Most likely problem is burnt out heater coils
Feb 02, 2009 | GE DVLR223 Dryers
Whirlpool Dryer not heating
This can be due to malfunctioning of any of these 4 devices..
1)Heating element
2)Thermal fuse
3)Thermostat
4)Timer motor
For more info and troubleshooting checkout this link..
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 22, 2007 | Whirlpool LER4634J Electric Dryer
Dryers Logo
114 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
