Question about Samsung SC-D103 Mini DV Digital Camcorder
I can not record because its in protection mode
I have tried to take of the protection mode , i see the icon but can not reach it to select the off position
  • 1 more comment
  • jenith1 Mar 29, 2008
    can not record because its in protection mode problem,
  • Anonymous Apr 28, 2008
    I have the same problem.
  • c_barr87 May 11, 2010
    My camera will not record at all nor will it playback my previous recordings, this just started happening about a half hour ago, and for the life of me i can not figure out why. In the upper left hand corner there is a hand with "(( ))" around it, and when I hit record the stand by (STBY) icon flashes and it will not go into record mode.I do not know if it is in protection mode or not.
I am having the same problem, i just dont know where to find the button to take off the protection, where would i find it
Posted on Mar 29, 2008
My 'the first years' baby monitor will only work when plugged into the wall. When I take the connection from the wall away the monitor switches off. Help please :)
Either the battery is dead or you need to change the sound setting that keeps unit off when it does not detect sound to protect the battery.
Another person said.
".We have this one. It must be in the sound activation mode, which helps to save the monitor's battery life. If it's in that mode, you'll see what looks like a crying baby icon along the top of the screen and the screen only turns on when sound is detected in the room.
To turn the mode off and keep the monitor on all the time, just press the Menu button on the right (in the middle of the arrows), press the right arrow until you reach the crying baby icon on the far right (so the icon gets big), press the Menu button, and a check mark and an X will appear - the X will be pre-selected and appear red. Just press the Menu button again to select the X and turn that mode off. Once back to the Menu screen, arrow up to the Return button on top right and press the Menu button to exit."
First years talk and soothe video monitor help
Nov 25, 2015 | Computers & Internet
What do "write protect" mean
1. Switch to playback mode using the mode
dial. Use the Left/Right buttons to locate
and display the photo or movie that you
want to protect.
2. Select the Protect setting from the
Playback menu as described previously.
3. Use the Up/Down navigation buttons to
select One to protect this picture/video,
or select All to protect all pictures/videos in
the internal memory or memory card. Then
press the Right navigation button.
4. Use the function button to select Yes to lock
the displayed picture/video or Unlock
to unlock it, and use the Up/Down
navigation buttons to select Back to
return to the Playback menu.
5. A key icon will appear on the top of
the screen to indicate that the picture/
video is protected.
6. Select reset to cancel protection for all
files that have been placed in the protected
Also keep in mind the card it self has a write protect on it if you hold the sd in front of you label side up its on the left hand side its just a little slide tab.
Jun 21, 2011 | Cameras
How will i change my camera (panasonic lumix dmc-fx37) languge from japanese to english
Slide the [REC]/[PLAYBACK] selector to the recording mode (camera icon). Set the mode dial to the camera icon. Press [MENU/SET] to display the menu. Press cursor-left, use cursor-up/down to select the wrench icon, then press cursor-right. Select the head-with-speech-bubble icon.
Apr 30, 2011 | Panasonic DMC-FX37 Digital Camera
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
How do I transfer a video from vcr to dvd on magnavok dvd/vcr recorder ?
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
(only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
Oct 27, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
Option window will appear.
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
Timer Programming
Auto Finalize
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
Using [
K / L], select “VCR DVD”. Hit [ENTER].
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
VCR to DVD duplication will start.
C] to stop the
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Recording. How to disable onscreen icons diplaying on record?
Go to camera Manu and check Display properties. There you will find display option on LCD or Video Output. select it Display On LCD.
Jul 29, 2008 | JVC GZ-MG130U Camcorder
Date stamp icon in the record menu
im trying to turn the date stamp function on from the record menu but cant select the function
Jul 29, 2008 | Canon PowerShot A400 Digital Camera
Embed audio notes
Since the C-5500 has audio recording capability it is possible to record brief audio notes, which become an embedded part of the image file. Open the MODE MENU and select the CAMERA tab. Toggle right to enter the CAMERA sub-menu and toggle down until you have selected the microphone icon, using the OK/MENU button. Then toggle right, select ON and press the OK/MENU button twice. The sound recording function is now enabled. About .5 seconds after the shutter is released the 4 second recording period will begin recording. You will need to point the microphone on the front of the camera toward the sound source. You can also record and record over audio notes on photos already taken. In the PLAYBACK Mode open the MODE MENU, select the PLAY tab and then select START. Pressing the OK/MENU button will start the 4 second recording period.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Samsung SC-D103 Mini DV Digital Camcorder Logo
186 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
