You need to make sure your laptop/PC is bluetooth compatible. Then if it is NOT then you need to buy a bluetooth dongle. My best bet would be from Newegg.com and then set it up through the disc it comes with. Sometimes they are pre-installed in the USB dongle, and then set it up. You should be then able to use the microphone from the headset if is enabled. If not go to the volume icon on the bottom or through the control panel and make sure you have selected it to be your output device.
To start with the forum needs to know if you have bluetooth capability on your PC. Does it have an internal bluetooth receiver? If not, you can get a USB receiver and from there install the headset. We will also need to know if you already use your PC to make internet calls. I am not familar with a headset being used otherwise. In any case, you still need a software program to interface for the chat session. Please advise as to what you have in mind.
