Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Cf3102 and Fiery
My cf3102 doesn't recognize the Fiery scan software any longer. The copier boots up and the Fiery icon no longer appears on the screen. I tried rebooting the Fiery, etc. Any suggestions?
  • Anonymous Jul 11, 2008
    the reason for this is simple. It is more than likely that the fiery hard drive has failed!! First check the connections from the fiery to the copier just to be safe. IF THEY ARE GOOD. Its dealer Time!
    the fiery harddrive is a standard Laptop HArddrive. changing it is fairly easy. That's the easy bit. Specialist software is then required to reload the fierys control software back on. AND EVEN WITH THE RIGHT STUFF ITS STILL HARD. You may get lucky by removing harddrive and putting it in a freezer for approx 30mins. then refit it. IT DOES WORK,but rarely lasts
  • Carlos Mendez
    Carlos Mendez Dec 08, 2013
    i reload the software, and it boot correctly, if you have this issue , reload the operating syste and it will work!!
    New Friend:
Yes I am having same problem nowadays. Pls let me know can I install big drive like 160 gb with this fiery.
Pls also let me know where can I download the software for fiery hard drive?
If we don't install the hard drive. Does it work without hard drive? Can it show the icon fiery icon without hard drive?
Pls suggest....
Posted on May 11, 2016
  • Sultan Haider Shabbir
    Sultan Haider Shabbir May 11, 2016
    Pls also share the windows 7 drivers for cf3102..
Did some one have the fiery cf3102 software system.efi that could share with me please????
Posted on Dec 01, 2011
  • 3 Answers
Replace the hard drive and reload Os version 2
Posted on Jul 10, 2008
  • 167 Answers
What occured before the Fiery went down?
Have you tried rebooting the actual Fiery? It has it's own switch apart from the Copier.
If you have already tried rebooting then it sounds like your Fiery has crashed and needs to be reinstalled.
Posted on Apr 09, 2008
I should have mentioned that I did reinstall the Fiery software and it didn't solve my problem. Has anyone else experienced this kind of problem?
Posted on Mar 24, 2008
Reinstall fiery system software.
Posted on Mar 23, 2008
SOURCE:
I had lost the driver CD of Xerox workcentre 3119,after down load the driver and scanner from Xerox website,the printing was back to normal,but can't scanning due to scanner icon doesn't appear at...
erm your best bet is to find where you installed the scan software and find the icon there. Once you fond it create a shortcut to that icon on the desktop.
May 10, 2011 | Xerox Office Equipment & Supplies
I have konica minolta cf3102 with scanner and fiery. printer is working properly and we have installed it but i have problem with scanner and i have no proper software for it. how i will be able to use the...
To use the scanner to scan to your computer you need to download and install the Fiery Remote Scan software ( available for pc or mac platforms).
It's available here:
remote scan 5
Nov 12, 2010 | Office Equipment & Supplies
Fiery EX12 hangs on booting no further process is...
You will need to reload the software in the Fiery.
May 20, 2010 | Xerox DocuColor 12 Printer
Fiery unit s400 will not work
If you press the Fiery button on the copier does the copier display the Fiery logo and the menu. If yes you are just missing the Fiery software for the workstation (called Command Workstation I believe). If no you will need a service call to possibly reload system software.
Feb 10, 2010 | Office Equipment & Supplies
Fiery scan not scan what problem
Fiery hard drive. Needs updated software down load. This is a service call.
Dec 01, 2009 | Xerox DocuColor 12 Color Copier
My fiery EXP 12 not booting what can I do to fix this problem
You should be able to plug a monitor into the fiery. Do that and turn off the machine and fiery. Then power up and watch the monitor and see where it hangs. If it doesn't boot up you may have to get a Xerox technician in to restore/ugrade the system software for the fiery.
Nov 22, 2009 | Xerox DocuColor 12 Color Copier
REQUIED WEB FOR KONICA MINOLTA SCCANER CF3102
Here's the link your looking for :)
http://onyxftp.mykonicaminolta.com/DownloadFile/Download.ashx?fileid=12417&productid=457
Google is Your friend, Just run the setup.exe leave the usb lead out of your machine until after the installation.
Jan 29, 2009 | Office Equipment & Supplies
Fault code 012-324
its fiery software problem reinstall fiery or restor fiery
Jan 20, 2009 | Xerox DocuColor 12 Color Copier
Booting problems with Canon CLC 1150 Copier
The copier itself doesnt have a hard drive. Since you are talking about Fiery I assume you mean the colorpass RIP attached to the copier. A CD with the software on it actually came with the RIP but it was probably swiped by the dealer. In any case it needs a SCSI CDROM in order to load it. But all is not lost. The hard drive actually keeps a backup of the software on the hard drive itself. Kinda like a system restore partition on some computers. When you switch it on hold down the top right button until the diagnostics pass. then press "restore backup". this will take quite some time. Once it is done you will have to go back into setup mode and re-enter all the network settings. Dont forget the default paper size.
Apr 28, 2008 | Canon CLC 1150 Color Copier
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
498 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
