Question about Kenmore 44072 Front Load Washer
Mouse droppings in the soap dispenser
We have regularly found fresh mouse droppings in the soap dispenser. How are the mice getting in there? Are they likely living in the machine? How do we keep them out?
Thanks!
  • 3,037 Answers
Mice can find a way to get into anything, I definitely believe they are living in there because it is probably a warm place most of the time and very protected for them. I would buy a couple of mouse traps and place them behind the machine with some peanut butter on them and wait until you no longer have a problem. They are probably getting in from under the machine. Hope this helps
Posted on Mar 22, 2008
  • Benjamin Patri
    Benjamin Patri Mar 22, 2008
    there is no good way to totally keep them out, because the ways they are getting in are probably places where the machine cools itself from
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    Have you done anything to solve this problem or do you have any other questions? We are here to help!
  • Kenmore Master
  • 19,396 Answers
Yes, sometimes they live in the machine, otherwise they get there form back of the machine.
  • Ginko
    Ginko Mar 22, 2008
    Move the machine, carefully lean the machine on one side and check the inside, probably you will find some undesired visitor. If not living inside the mice must be getting in from the back. Then they climb on top of the basket, and end up dieing in the detergent drawer.
    Use Traps and/or poison to get rid of the problem.
    Most effective in this case is glued paper traps placed around and a the back of the machine, after you clean machine inside.
    Regards
Hello. A mouse has chewed through the dispenser hose (hose between soap dispenser & drum) on my Fagor FU6146IT washing machine. Is it the sort of thing I can replace myself? Thank you!
Mice are helpful little creatures...
Mostly if you can take the top off the machine yourself you should be able to replace the hose yourself.
Apr 01, 2017 | Fagor Washing Machines
Soap dispenser door will not open. Regular wash cycle time varying a great deal when machine turned on.
The soap dispenser is probably faulty. Wash times can vary. The main controller will determine the wash time and will change according to water temp when filling, time it takes to fill, etc. Check and make sure the filters at the bottom are clean.
Feb 23, 2015 | Bosch 24 in. SHY66C05 Stainless Steel...
I just bought a washer and dryer that were used and the previous owner was a smoker. Now all my clothes smell like smoke. Any advice the get the smell out of the machine?
Hello, W/D here.
For a single odor, I would recommend a neutralizing sequence. Use one box of baking soda. Fill the soap dispenser as you would with powdered soap, and pour the remainder into the wash tub. Fill the fabric softener and bleach dispenser cups with an odor remover such as Odor-Cide or Febreze. Add 1/2 the normal amount of detergent for a normal load directly into the tub. Run the washer on the hottest, longest cycle available, with the longest, hottest rinse cycle available (usually this is the sanitary cycle). When the cycle has finished, run another sanitary cycle with 2 cups of bleach in the tub, fill the soap dispenser, bleach dispenser and the softener dispenser with bleach also.
After this cycle runs, run another, normal cycle with white vinegar in the tub and dispensers. This can be a normal cycle.
After all of these cycles, one last regular cycle with about 1/2 the normal amount of detergent in the dispenser should get all of the smell neutralized in the machine.
Best regards, Woobie ‰ Dog Please take a momentto rate our solutions so that we may improve in helping others. Thanks.
Feb 24, 2011 | Washing Machines
My simple human sensor Soap Dispensor will not
Hi, you have this question in the wrong park of the site. But I did a quick google search and believe I may have found an answer for you. I'll copy and past what I found for you here. If this doesn't solve the issue you should probably repost this question
"In the spot where the soap dispenses, there is a very small plug which controls the flow which you need to gently pull out and release (not break off) in order to break the vacuum seal. This information is not included in the regular instructions, but rather is written on a small 2-inch square piece of paper in the box. I was getting very frustrated because I had "primed" the soap dispenser at least 30 times and nothing had come out. I noticed the small plug, and while looking through the box again found the small piece of paper with the additional instruction. After that, it worked great! I use a generic version of Soft Soap, and we find the lowest setting dispenses more than enough soap."
Mar 04, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Water coming out of soap drawer
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Feb 05, 2010 | Hotpoint First Edition WMA22 Front Load...
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Husband mis filled ge profile washer dispeser. can we use mixed solution or should we throw it out
Did he overfill the soap dispenser with extra automatic dishwasher soap or with something else? If it is just automatic dishwashing soap then maybe run the cycle with no dishes in it on heavy wash. Now if he filled it with regular dishwashing soap clean out as much of it as you can then run the washer without dishes. If you leave regular soap in there your kitchen will be filled with bubbles.
Sep 13, 2009 | Washing Machines
Mouse not responding to movements
Try using fresh batteries and reconnect the mouse to its wireless receiver.
If you get the same problem, connect the receiver into different USB ports of the computer, or try different computer.
Otherwise, you need to contact the manufacturer for possible RMA.
Have a great day!
Jul 09, 2009 | HP Wireless Optical Mouse
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Jan 22, 2008 | GE WBVH6240F Front Load Washer
Kenmore 44072 Front Load Washer Logo
204 people viewed this question
Sal De
fordexpert
Robert Rankin
