I have a problem with my Dell AIO 924 printer bought in November 2005. I think there is a problem with the rollers grabbing the paper to print. It grabs a few at a time or none at all. The paper does not seem to fit properly into the slot appropriated for it. I never had this problem before. What could be wrong?
  • 19,396 Answers
In some case this is due to a mechanical problem. Most often the cause is simpler, for examplample you are using a paper type different from one for which the printer is currently set. I also saw same problem caused by a small foreign object lost inside the printer (I found 5 p coin once, size of a dime, the object was not detected by printer but disturbed paper load function).To check the inside take the cartridges out, check inside and stuck your fingers down where the paper feeds in. If you find any object (eg paper) keep fiddling with the rollers until you get the object.
Check also that the printer is set to use same paper that you are loading into the tray.
Regards
regards
Posted on Mar 23, 2008
  • 3,037 Answers
Maybe if you changed the brand of paper, the paper may have a slight thickness change, usually the brand of printer recommends its own paper.
Otherwise I would go with some kind of wear damage which may just result in a new printer or you will have to tear it apart I'm sorry to say
Posted on Mar 22, 2008
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    How is this printer problem going, have you solved it? Need any more help? Have a good day and let us know if anything comes up!
    Genius:
  • 3,422 Answers
HI,
The problem is with the roller and you will have to replace it or get it repaires by a technician.I'm not sure if the roller can be replaced or not - however, here's a quick way to fix that roller...
get a piece of thin fine to light sandpaper, and put it in the paper tray - tell the printer to print, and when it starts to pull the sandpaper in, hold it so that it will roughen up the rollers.
This tirck ususally works..
Goodluck,
Please don't forget to rate the solution.
  • 790 Answers
Hello justjudith52 ,
For the not grabbing the paper try cleaning the roller with a lint free cloth & alcohol. you will not beable to just replace the roller assembly it would be the whole cover/ assembly i believe and should be done by a repair shop, so hopefully just cleaning the roller will help.
    Genius:
  • 1,665 Answers
It must be mechanical damage on gear and moving shaft connection.
  • Anonymous Mar 22, 2008
    Regularly you can not find spare parts (are not available or not cost effective way), so if you can have access to it removing cover and use a good glue at plasti gear fitting to moving shaft.
    To remove cover usually you need a special screw driver.
SOURCE:
My Dell AIO 924 printer will not feed paper.
1.Check inside the printer to see if you have the ink properly installed.
2.Make sure you don't you re-use papers that you have already used.
3.All papers have to be perfectly allined.
4.Check the connection wires between the computer and the printer.
5.Scan your computer with a security system to catch and eliminate viruses,tracking cookies etc.
If all else fails I don't know what to say
Jun 24, 2012 | Dell 924 All-in-One InkJet Printer
My Dell 924 CLAIMS it has a paper Jam and does NOT.... it will not clear this out and I can't print anything! Help!
check the feed rollers for a dirt build up , they can be cleaned with a damp cloth, the probable cause is slipping feed, the printer expects paper and none is fed due to the slipping of the rollers.
look where the front edge of the paper sits, there are rollers there that bring the paper into the printer, clean them.
Jan 11, 2011 | Dell 924 All-in-One InkJet Printer
It starts to feed and the rollers keep going and the paper stops and does not print
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
catalog.ebay.com/Dell-924-All-One-Inkjet-Printer-/50399257/r.html
Jul 02, 2010 | Dell 924 All-in-One InkJet Printer
Paper feed issue with Dell AIO 810 printer - paper feeds @ 1/4 way down initially, but is not "grabbed" to feed through to print
This is due paper pull rollers may having the issue. repair/replace the rollers will resolve your problem.
Thank you for using Fixya.
Mar 16, 2010 | Dell 810 All-In-One InkJet Printer
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
Dell Photo AIO Printer 924 - Printer Busy
Might need a new printer. Lexmark printers can be troublesome.
Jul 14, 2009 | Dell 924 All-in-One InkJet Printer
Wrong ink color Dell 924 printer
run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 25, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 all in one will not print magenta
Thanks, Joe
Nov 19, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Oct 29, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 all in one printer problem
Try cleaning the rubber rollers for the paper pick up, there may be some paper fibers on them, and they are not grabbing the paper properly. Use a damp lint free cloth and whipe them, or rubber roller cleaner.
Jan 15, 2007 | Dell 924 All-in-One InkJet Printer
Open Questions:
AOL MAil SuPPoRt USA {1-855*536*5666}#[email protected] PHoNe NuMbER ARIZONA This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I855%536%5666 is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 16, 2019 | AOL Computers & Internet
Computers & Internet Logo
64 people viewed this question
Ekse
Alun Cox
