The washer sprung a leak, and now the dryer does't work after getting wet.Is it a fuse or what should I do?
SOURCE: what does a thermal fuse look like
the fuse is a small plastic piece with only 2 wirs connected to it and it will be behind the back cover or the ones that the back dont come off, it is inside the lower panel in front ,,, check your break ,,,, it may have trip it even if it dont look or feel like it.
Larry
Posted on Nov 25, 2008
Oct 03, 2014 | LG DLEX2550W 27" Front-Load Electric Dryer
Dec 04, 2012 | Whirlpool LER5636P Electric Dryer
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
In Stock
Quantity:
http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Nov 09, 2017 | GE DCVH515EFWW Electric Dryer
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 09, 2011 | Dryers
Aug 14, 2009 | Equator EZ 3612 CEE Front Load...
Aug 03, 2009 | Maytag MDG6000 Dryer
Mar 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Jan 22, 2009 | Bosch Axxis WTL 6003 Electric Dryer
Nov 03, 2008 | Kenmore 62602 Electric Dryer
Apr 04, 2014 | Whirlpool LER5636P Electric Dryer
773 people viewed this question
