Question about Vacuums
Bissel proheater I have a Bissel proheater 7901. When you power on the spray works fine for 2-3 seconds then will not spray. Power off for 30 seconds and then repeats the same thing again when powered on. I'm thinking the pump is bad. Any other ideas?
    President:
  • 1,673 Answers
Will water squirt out of the hose? If it does, then you could have a clogged heater, which is in the handle. Check the bottom of the tank, is the round seal on the valve that is on the tank bottom? If not, it has to be there. Another thing is the top and bottom together in the back? Sometimes it breaks loose and the top raises alittle, which will raise the tank so it won't feed water. The pump could be bad, but I would check the other things first.
Posted on Mar 22, 2008
I cant get my bissel proheat pet to spray water have replaced pump and cleaned heater sprays a little then stops any ideas?
You may want to contact a BISSELL Authorized Service Center to have a qualified technician inspect your machine.
Here's a quick link to locating one. http://www.bissell.com/service-centers/?cid=ccsocial
Dec 08, 2012 | Bissell 7901-1 ProHeat Scotchgard Upright...
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Water does spray out when using floor bissel proheat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Mar 28, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
My bissell7901 is spraying water out by the wheels
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101 sfdgd
Bissel pro heat wont dispense any water
these pumps always fail. try to replace the pump. also check for clogs in the spray nozzles and tubes
Feb 26, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Instruction manual for a bissel proheat model
heatman101
Jun 04, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Proheat 7901-R not doing anything--ready to scream!
heatman101
ewtywe
Mar 12, 2009 | Bissell 7901-R Clearview Proheat Plus...
Vacuums Logo
64 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
