Question about Mintek MDP-1060 10.2-in 16:9 Portable DVD/CD Player Headphones&Case Included
Difficulty Recharging Battery
When I plug the AC adaptor into the DC IN, the power on/charge indicator lights. The battery would charge normally, with the light going off once the battery is recharged. Now, however, the battery is not recharging. When I move (jiggle) adaptor plug in DC IN socket, the power on/charge indicator light will flicker. If I put some slight tension on the adaptor cord (e.g., be stretching the power cord over the top of the player and pushing the cord into the area on the top left of player where the hinge is), there was a period where I could get the battery to recharge but this no longer seems to be the case. My suspicion is the the DC IN part has a loose connection or partial short inside the player (e.g., repairing the problem may only require making sure the connection inside is properly soldered). I tried to contact Mintek about the problem and found they've gone out of business. Have you had reports of this kind of problem w/ battery not recharging because of a loose connection between the DC IN part and what it connects to inside the player? Do I need a replacement part, or just open the player (myself?) and make sure a connection is properly soldered? Or should I take the player to a local electronics repair shop? If I can provide more info to help you diagnose the problem and identify a solution, please advise. Other than this the play works fine (other than, when battery is de-charged, I need to manually hold the adaptor plug in just the right position for the player to keep playing). Thanks, Kerry
    Genius:
  • 3,422 Answers
HI,
the problem is not with the battery it is with the adapter as you said that is you hold the adapter in roght position the liight comes on and it charges.The solution will be to buy an adpter for it and im sure this will solve your problem.
Goolduck.
Posted on Mar 22, 2008
  • 3,037 Answers
I've seen a similar problem with a friend's laptop, he could plug it in and use the laptop but it would not recharge the battery.
The problem we found after opening it up was that a piece of metal had broken and all it took was a quick solder of it and it was solved. If that's not it then good luck but I believe you are right in your thinking. It's probably just a thin piece of metal that snapped from who knows what. My friend accidentally had his dog step on it I believe and it broke but it doesn't sound like a hard problem to fix. Good luck with it and let me know if my solution doesn't work.
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    Have you tried to solve this problem yet or do you need any more help? We are here to help, just ask! Thank you and have a great day!
  • 4,102 Answers
Hi this is a common problem with most devices of this type expecially mobile phones what you can do is buy a new adaptor you can buy multi adaptors that you can change the voltage and come with different connectors you can fit onto the end.
You can buy these from most diy shops and are cheap to buy.
If you cant buy one then what i did but im not advising you to is strip back the wires from the outer case where the adaptor is and resolder them onto the adaptor as they split and short not allowing you to charge.
The problem is going to be with the adaptor and not the device i would suggest buy a multi adaptor take yours with you so you get the right one and ask staff to check for you as you dont want to damage your equipment this is the best option for you
  • paul proctor Mar 22, 2008
    As the battery light is flickering then it is going to be the lead is failing causing a short between the wires causing it stop charging.
    Its best not to try using it as it can cause damage to your equipment and even the battery so i would goto a diy shop and buy an adaptor that you can change the voltage on i have had to buy these before for things like psp and playstation2 so i know they work just remember to get right voltage and right amp as this can cause problem but the staff should point you in the right direction
    If you read the voltage and amps of the mains adaptor ill have a look for you and tell you the best one to use as buying an original can take time and also be expensive but a multi one can be cheap to buy and just as reliable
  • 2,326 Answers
This type of connectors become loose easily because of all the plug ins that take place to recharge the battery.
I would suggest to open the device, but be very careful when doing it and check for a loose solder joint just where the DC IN is solder on your device.
Let me know if you need further assistance.
  • Mintek Master
  • 19,396 Answers
You need to change the battery, not the adapter
  • Ginko
    Ginko Mar 22, 2008
    If the power on/charge indicator lights then the power adapter is fine. when you moved adaptor plug in DC IN socket, causing the power on/charge
    indicator light to flicker you were creating a short inside your dvd. By accident this used to deliver in some way some charge to the battery, but at same time you were risking all the time to blow your device.
    Before opening the device to eventually solder the ac adapter connector you should test if power is getting to the battery to recharge it. Do this with a multimeter tester or using a replacement battery.
    Only after this you open the machine and try fixing problems on the inside board.
    The adaptor is soldered to the board by four contacts, when one contact is faulty the unit will not power up.
    If it is not the battery itself, it is most likely a contact going to the battery charge that is interrupted. Probably you caused a short that in some way connected it back whilst pulling the power cable.
    I suggest testing the battery contacts(the ones inside dvd battery box, with no battery inside), or trying a replacement battery.
    If the above does not work I suggest to bring it to a service centre.
    regards
  • Ginko
    Ginko Mar 22, 2008
    Here is a price list for multimeter/tester.
    Cheap ones cost around $10, they are still ok for your needs.
    Apply it to power adapter male connector (the one on power adapter cable. If power is coming out with same voltage as specs on sticker then your power adaptor is fine, do not change it.
    Do the same with contacts inside battery box and power adapter plugged, if you have power over there, then it is the battery for sure.
    If it is none of the two above then may be the female power connector on the Device, as you suspected, or some other problem inside.
    regards
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
Hi8 manual
See pic below.
1. Open the DC IN jack cover and connect the supplied AC power adaptor to the DC IN jack with the plug's mark arrow up
2. Connect the power cord to the AC power adaptor.
3. Connect the power cord to a wall outlet.
4. Slide the POWER switch to off. Remaining battery time is indicated by the minutes on the display window. Charging begins.
Apr 25, 2014 | Video Cameras
It just showed up with NO battery life and I have it plugged into A/C all the time. Also the lights on the left front edge are blinking. Is that normal or not?
try to check if the battery can be charge in full and how long it will last. if the indicator is still binking even plug in the AC and ongoing charge for several hour,your battery might need a replacement... for the meantime while using AC adaptor,just remove the battery pack and continue using on a power supply to avoid power interruption
hope it helps...rate my solution please....thanks
Jun 05, 2011 | Computers & Internet
Charge isn't consistent. Orange light flashes instead of remaining on when charging.
Are you using the original ac power adapter, or one that is designed for use with your model to ensure that it is fitting tightly where it plugs into the laptop at the dc jack?
If so, the dc jack could be broken, which could prevent the battery from charging properly, resulting in the flashing amber light, which is indicating that the battery is still low and needs recharging.
Another possibility is that the battery is defective, but the more likely problem is the dc jack since it is such a common problem.
You can find a replacement dc jack here.
http://www.laptoppartsexpert.com/c-49361-toshiba-satellite-a130-a135-series-a135-s2276.html
Good luck, please let me know if it helps.
Thanks
May 08, 2010 | Toshiba Satellite A135-S2276 Notebook
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
My Gateway 1450 will not power up. For the last 2 weeks that battery light has been red (battery need recharging). i had the unit turned off with no ac power to it all weekend and not it will not power up....
The motherboard battery is just a little round battery that you can buy at almost any retailer in most pcs. The model number to the battery is usually a CR 2032. This battery does not receive any power from your power supply. Have you noticed your PC loosing time over the last few months? This is usually a good indication that the motherboard battery is dying. The lights that you refer to though should only partain to the rechargable battery of the notebook. During the past two weeks while the red light was on, was the AC adaptor plugged in to the laptop and plugged into an AC source? If your AC adaptor has been plugged in and is not charging the notebook battery then there could be one or both of the following problems: your notebook battery could be bad or your AC adaptor could be bad. Something you may or may not know is that it is not good to keep the AC adaptor plugged in all the time. This causes the notebook battery not to fully discharge after being charged. Over a long period of time, the battery will not even charge anymore. My suggestion is that if you know someone with a similar AC adaptor to yours, borrow it to see if it charges your battery. If the battery doesn't charge then you know to replace. However, I am almost certain that you problem is the battery. Sometime older laptops like the one I have has a reset button on the underside. If yours has one try removing the battery and leave it out. Then plug in the power and press and hold the reset button for 10 to 20 seconds. If no reset button is on yours then do the same process with the battery removed and power adding, but hold the power button instead.
Dec 07, 2009 | Gateway Solo 1450 Notebook
Wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Dec 16, 2008 | Toshiba Satellite A100-S8111TD Notebook
Battery is not charging
Charger board seems to have gone bad.
Aug 05, 2008 | HP NC4010 Notebook
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
Mintek MDP-1060 10.2-in 16:9 Portable DVD/CD Player Headphones&Case Included Logo
140 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
