Question about Frigidaire ATF6000ES Front Load Washer
Error code LOC
I unplugged washer to use outlet and when I replugged washer I received ERR LOC. Can anyone advise on how to reset?
  • Anonymous Mar 24, 2008
    Called customer service at Frigidaire/ Electrolux and they walked me through the reset procedure. Machine works perfectly and I saved $139.00 which is what the service call would have cost.
  • 770 Answers
That is a control locked sign you need to relase the Child lock from the control panel and this should be in your manual if not go to their website and you can download the use and care guide
Posted on Apr 01, 2008
  • Gary Davd
    Gary Davd Apr 01, 2008
    NOTE:
    During normal operation, the displaymay show:
    “SAn”
    - deep clean (Sanitary Cycle)
    cd” - cool down (Sanitary cycle)
    do” or “dr” - door problem.
    Err” - an error has been detected.
    LOC” - control lock is activated.
    PAU” - cycle has been interrupted.
SOURCE:
My Electrolux time manager washing machine wont start jus flashes red with Err
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
Oct 04, 2014 | Washing Machines
I have a frigidaire front loading washer and when I try to start it, the error message reads "LOC"
Good Afternoon Friend, thank you for allowing me to assist you!
If you are getting an error code LOC on your Frigidaire washer, it usually means that your control panel is locked. Let's attempt pressing and holding OPTIONS and SELECT at the same time for about 10 seconds. This usually does the trick. If not, you may want to try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is good to wait roughly ten minutes and then turn on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Thank you! - Z
Aug 29, 2014 | Frigidaire Washing Machines
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
Kenmore washer model44082 will not work. It flashed err and LOC. I have unplugged and tried to cancel.it still flashes err and then LOC.
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Kenmore HE2 Plus Front Load Washer
417.44092500 front load washer I get a LOC err,
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 30, 2009 | Kenmore 46462 Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Error code LOC
Jun 27, 2009 | Kenmore 44932 Front Load Washer
Error code ERR on Sears Kenmore front load washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2009 | Kenmore Washing Machines
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Jun 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Frigidaire ATF6000ES Front Load Washer Logo
162 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
